Showing results forĀ
Search instead forĀ
Did you mean:Ā
backing up voicemail recordings
raypjones
Hello all, I have a uc540 and I want to back up the diffrent voicemail greetings. I have been looking and ill i can find is how to make a new gretting or delete a greeting.
Hi Raymond.
On Unity Express administration page, select "Voicemail" --> Prompts
You can select all prompts and download them
Reagrds
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
You can also download the same by login through CUE admin page. it allows only you download one by one.
SYSTEM--->PROMPTS (you will list of prompts to be downloaded)
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
