Backup CCM5
JustForVoice_2
Level 4
Level 4
I need to upgrade CCM5 to CCM7
I tried to backup the server, somebody added network device as SFTP before I need to chage the IP for the backup device but I could not. if I change the IP address, path, username and password then press save the old IP, path, username and password came.
any idea??
William Bell
Have you confirmed that you have the following information correct:
- username
- password
- folder path
It is possible the CUCM is attempting to validate the information and failing. I believe I have seen this before (where the settings would stay the same), though my recollection is that it came with an error message. You didn't report an error message, so maybe I am barking up the wrong tree. In either case, it is a good idea to test the SFTP server from either the CUCM command shell or from an independent station.
On a different angle, have you tried to create a new backup destination using the new server IP/credentials? Since the information has changed, there is no reason to keep the erroneous configuration around. I would check that your info is accurate first and then delete the existing and/or add the new backup server.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
I am sure I tried to adjust the information in a right way.
I added the IP, Path, Username and password. but I do not think I can add more than one device in CCM5 it is not like CCM7
anyhow I will try to check using the CLI and I will check if there is nay firewall on the PC so the server can not access and check the information.
Aaron Harrison
If you type a new user/pass/path and it fails, then it means you have bad information put in to the page.
CCM validates all the above when you enter it.
Verify, and try again.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
