Bad Decrypt CUCM DRS/DRF backup and restore
William Childs
I came across the following when upgrading an offline server from 7.1.5 to 8.6.2. I was using an MCS 7835-h2 server for a staged upgrade and took a backup of 7.1.5. Then performed a restore to a lab server then upgraded to 8.6.2. Then I took a backup and tried to restore to a new / freshly installed 8.6.2 on a UCS C200 server. I used the 8.6.2 OVF template to build the VM and was experiencing the following errors when trying to restore:
Log File: 2013-03-01-22-13-31_r_bwd1-ccm-01_ucm_ccmdb.log
Server : BWD1-CCM-01
Feature : UCM
Component : CCMDB
Time Completed: 2013-03-01-22-17-57
Result Code : 1-Please check the component logs for further details.
Result String : ERROR
CCMDB ready to restore
03/01/13 22:17:28 - command to execute /bin/chmod 777 /common/drf/restore.log
03/01/13 22:17:28 - Starting a DRF Restore.
03/01/13 22:17:28 - Restoring the tarball
03/01/13 22:17:30 - Restoration of the tarball is done.
03/01/13 22:17:31 - "Nodes in cluster:" 1
03/01/13 22:17:31 - command to execute /bin/chmod 777   /common/drf/db_drf_backup
03/01/13 22:17:31 - command to execute /bin/chown informix:informix   /common/drf/db_drf_backup/drf_ontape_backup.gz
03/01/13 22:17:31 - command to execute /bin/chmod 664   /common/drf/db_drf_backup/drf_ontape_backup.gz
03/01/13 22:17:31 - command to execute /bin/rm -f   /common/drf/db_drf_backup/drf_ontape_backup
03/01/13 22:17:31 - Unzipping the database backup.
03/01/13 22:17:31 - command to execute /bin/gunzip   /common/drf/db_drf_backup/drf_ontape_backup.gz
03/01/13 22:17:31 - Database backup unzip is done.
03/01/13 22:17:33 - Checking to see if the database is up
03/01/13 22:17:33 - command to execute /bin/su - informix -c "onstat   -"
03/01/13 22:17:33 - Database is up
03/01/13 22:17:33 - Shutting down the database and starting a restore.
03/01/13 22:17:33 - command to execute /usr/local/cm/bin/controlcenter.sh   "A Cisco DB" stop
03/01/13 22:17:56 - command to execute /bin/su - informix -c "onmode   -kcy; ontape -r >/common/drf/restore.log
shared memory not initialized for INFORMIXSERVER   'bwd1_ccm_01_ccm8_6_2_22900_9'
03/01/13 22:17:57 - CCMDB Restore failed, ontape restore failed, error: 1
03/01/13 22:17:57 - command to execute /bin/su - informix -c "onmode   -yck" >>/common/drf/restore.log
----> BEGIN Standard Output
/usr/local/cm/db/csv/products/
/usr/local/cm/db/csv/products/Product_462.csv
/usr/local/cm/db/csv/products/Product_451.csv
/usr/local/cm/db/csv/products/Product_498.csv
/usr/local/cm/db/csv/products/Product_30316.csv
/usr/local/cm/db/csv/products/Product_30040.csv
/usr/local/cm/db/csv/products/Product_371.csv
/usr/local/cm/db/csv/products/English_United_States_Locale.csv
/usr/local/cm/db/csv/products/Product_30274.csv
/usr/local/cm/db/csv/products/Product_21.csv
/usr/local/cm/db/csv/products/Product_435.csv
/usr/local/cm/db/csv/products/QEDTypes.csv
/usr/local/cm/db/csv/products/Product_334.csv
/usr/local/cm/db/csv/products/Product_30312.csv
/usr/local/cm/db/csv/products/Product_368.csv
/usr/local/cm/db/csv/products/Product_65.csv
/usr/local/cm/db/csv/products/Product_475.csv
/usr/local/cm/db/csv/products/Product_392.csv
/usr/local/cm/db/csv/products/Product_484.csv
/usr/local/cm/db/csv/products/Product_20003.csv
/usr/local/cm/db/csv/products/Product_30280.csv
/usr/local/cm/db/csv/products/Product_30023.csv
/usr/local/cm/db/csv/products/Product_208.csv
/usr/local/cm/db/csv/products/Product_482.csv
/usr/local/cm/db/csv/products/Product_30299.csv
/usr/local/cm/db/csv/products/Product_437.csv
/usr/local/cm/db/csv/products/Product_45.csv
/usr/local/cm/db/csv/products/Product_24.csv
/usr/local/cm/db/csv/products/Product_355.csv
/usr/local/cm/db/csv/products/Product_72.csv
/usr/local/cm/db/csv/products/Product_30298.csv
/usr/local/cm/db/csv/products/Product_480.csv
/usr/local/cm/db/csv/products/Product_58.csv
/usr/local/cm/db/csv/products/Product_380.csv
/usr/local/cm/db/csv/products/Product_467.csv
/usr/local/cm/db/csv/products/Product_268.csv
/usr/local/cm/db/csv/products/Product_70.csv
/usr/local/cm/db/csv/products/Product_30293.csv
/usr/local/cm/db/csv/products/Product_30059.csv
/usr/local/cm/db/csv/products/Product_257.csv
/usr/local/cm/db/csv/products/Product_449.csv
/usr/local/cm/db/csv/products/Product_30022.csv
/usr/local/cm/db/csv/products/Product_501.csv
/usr/local/cm/db/csv/products/Product_30020.csv
/usr/local/cm/db/csv/products/Product_30282.csv
/usr/local/cm/db/csv/products/Product_30011.csv
/usr/local/cm/db/csv/products/Product_275.csv
/usr/local/cm/db/csv/products/Product_504.csv
/usr/local/cm/db/csv/products/Product_335.csv
/usr/local/cm/db/csv/products/Product_445.csv
/usr/local/cm/db/csv/products/Product_30272.csv
/usr/local/cm/db/csv/products/Product_30315.csv
/usr/local/cm/db/csv/products/Product_206.csv
/usr/local/cm/db/csv/products/Product_473.csv
/usr/local/cm/db/csv/products/Product_44.csv
/usr/local/cm/db/csv/products/Product_20000.csv
/usr/local/cm/db/csv/products/Product_495.csv
/usr/local/cm/db/csv/products/Product_444.csv
/usr/local/cm/db/csv/products/Product_500.csv
/usr/local/cm/db/csv/products/Product_520.csv
/usr/local/cm/db/csv/products/Product_499.csv
/usr/local/cm/db/csv/products/Product_30044.csv
/usr/local/cm/db/csv/products/Product_333.csv
/usr/local/cm/db/csv/products/Product_514.csv
/usr/local/cm/db/csv/products/Product_496.csv
/usr/local/cm/db/csv/products/Product_472.csv
/usr/local/cm/db/csv/products/Product_30057.csv
/usr/local/cm/db/csv/products/Product_464.csv
/usr/local/cm/db/csv/products/Product_273.csv
/usr/local/cm/db/csv/products/Product_30292.csv
/usr/local/cm/db/csv/products/Product_69.csv
/usr/local/cm/db/csv/products/Product_30065.csv
/usr/local/cm/db/csv/products/Product_30286.csv
/usr/local/cm/db/csv/products/Product_207.csv
/usr/local/cm/db/csv/products/Product_345.csv
/usr/local/cm/db/csv/products/Product_491.csv
/usr/local/cm/db/csv/products/Product_330.csv
/usr/local/cm/db/csv/products/Product_30076.csv
/usr/local/cm/db/csv/products/Product_264.csv
/usr/local/cm/db/csv/products/Product_470.csv
/usr/local/cm/db/csv/products/Product_30019.csv
/usr/local/cm/db/csv/products/Product_66.csv
/usr/local/cm/db/csv/products/Product_30052.csv
/usr/local/cm/db/csv/products/Product_390.csv
/usr/local/cm/db/csv/products/Product_503.csv
/usr/local/cm/db/csv/products/Product_30291.csv
/usr/local/cm/db/csv/products/Product_30018.csv
/usr/local/cm/db/csv/products/Product_104.csv
/usr/local/cm/db/csv/products/Product_23.csv
/usr/local/cm/db/csv/products/Product_407.csv
/usr/local/cm/db/csv/products/Product_479.csv
/usr/local/cm/db/csv/products/Product_30006.csv
/usr/local/cm/db/csv/products/Product_506.csv
/usr/local/cm/db/csv/products/Product_100.csv
/usr/local/cm/db/csv/products/Product_30290.csv
/usr/local/cm/db/csv/products/Product_336.csv
/usr/local/cm/db/csv/products/Product_62.csv
/usr/local/cm/db/csv/products/Product_234.csv
/usr/local/cm/db/csv/products/Product_515.csv
/usr/local/cm/db/csv/products/Product_478.csv
/usr/local/cm/db/csv/products/Product_227.csv
/usr/local/cm/db/csv/products/Product_519.csv
/usr/local/cm/db/csv/products/Product_105.csv
/usr/local/cm/db/csv/products/Product_20.csv
/usr/local/cm/db/csv/products/Product_311.csv
/usr/local/cm/db/csv/products/Product_30270.csv
/usr/local/cm/db/csv/products/Product_36.csv
/usr/local/cm/db/csv/products/Product_30066.csv
/usr/local/cm/db/csv/products/Product_30041.csv
/usr/local/cm/db/csv/products/Product_47.csv
/usr/local/cm/db/csv/products/SCCP.csv
/usr/local/cm/db/csv/products/Product_80.csv
/usr/local/cm/db/csv/products/Product_230.csv
/usr/local/cm/db/csv/products/Product_106.csv
/usr/local/cm/db/csv/products/Product_274.csv
/usr/local/cm/db/csv/products/Product_408.csv
/usr/local/cm/db/csv/products/Product_30060.csv
/usr/local/cm/db/csv/products/Product_30005.csv
/usr/local/cm/db/csv/products/Product_366.csv
/usr/local/cm/db/csv/products/testing.html
/usr/local/cm/db/csv/products/Product_483.csv
/usr/local/cm/db/csv/products/Product_434.csv
/usr/local/cm/db/csv/products/Product_43.csv
/usr/local/cm/db/csv/products/Product_247.csv
/usr/local/cm/db/csv/products/Product_20002.csv
/usr/local/cm/db/csv/products/Product_35.csv
/usr/local/cm/db/csv/products/Product_367.csv
/usr/local/cm/db/csv/products/dependency.txt
/usr/local/cm/db/csv/products/Product_30266.csv
/usr/local/cm/db/csv/products/Product_30004.csv
/usr/local/cm/db/csv/products/Product_507.csv
/usr/local/cm/db/csv/products/Product_119.csv
/usr/local/cm/db/csv/products/Product_232.csv
/usr/local/cm/db/csv/products/Product_202.csv
/usr/local/cm/db/csv/products/Product_68.csv
/usr/local/cm/db/csv/products/Product_502.csv
/usr/local/cm/db/csv/products/Product_477.csv
/usr/local/cm/db/csv/products/Product_513.csv
/usr/local/cm/db/csv/products/Product_30050.csv
/usr/local/cm/db/csv/products/Product_383.csv
/usr/local/cm/db/csv/products/Product_30002.csv
/usr/local/cm/db/csv/products/Product_30007.csv
/usr/local/cm/db/csv/products/Product_46.csv
/usr/local/cm/db/csv/products/Product_382.csv
/usr/local/cm/db/csv/products/Product_471.csv
/usr/local/cm/db/csv/products/Product_32.csv
/usr/local/cm/db/csv/products/Product_34.csv
/usr/local/cm/db/csv/products/Product_30071.csv
/usr/local/cm/db/csv/products/Product_30013.csv
/usr/local/cm/db/csv/products/Product_30297.csv
/usr/local/cm/db/csv/products/Product_59.csv
/usr/local/cm/db/csv/products/Product_494.csv
/usr/local/cm/db/csv/products/Product_30319.csv
/usr/local/cm/db/csv/products/Product_427.csv
/usr/local/cm/db/csv/products/Product_30053.csv
/usr/local/cm/db/csv/products/Product_469.csv
/usr/local/cm/db/csv/products/Product_497.csv
/usr/local/cm/db/csv/products/Product_30202.csv
/usr/local/cm/db/csv/products/Product_71.csv
/usr/local/cm/db/csv/products/Product_229.csv
/usr/local/cm/db/csv/products/Product_365.csv
/usr/local/cm/db/csv/products/Product_384.csv
/usr/local/cm/db/csv/products/Product_115.csv
/usr/local/cm/db/csv/products/Product_303.csv
/usr/local/cm/db/csv/products/Product_22.csv
/usr/local/cm/db/csv/products/Product_228.csv
/usr/local/cm/db/csv/products/NANP.csv
/usr/local/cm/db/csv/products/Product_424.csv
/usr/local/cm/db/csv/products/Product_493.csv
/usr/local/cm/db/csv/products/Product_30038.csv
/usr/local/cm/db/csv/products/Product_235.csv
/usr/local/cm/db/xml/xml/
/usr/local/cm/db/xml/xml/3945_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/3825_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_7911_rules.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/1751_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/RTMTReporter_Rules.xml
/usr/local/cm/db/xml/xml/269X_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-t1cas_port_gs.xml
/usr/local/cm/db/xml/xml/usageprofile_rules.xml
/usr/local/cm/db/xml/xml/3725_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/CAPF_Rules.xml
/usr/local/cm/db/xml/xml/RIS_Data_Collector_dependencies.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Cisco_IP_Voice_Media_Rules.xml
/usr/local/cm/db/xml/xml/Product_514_rules.xml
/usr/local/cm/db/xml/xml/FC_EMCC.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/364X_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/1861_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/1861_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_7906_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/3745_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/2921_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/MITRA_Display_Instance.xml
/usr/local/cm/db/xml/xml/Phone_7931_display_instance.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_6911_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7911_display_instance.xml
/usr/local/cm/db/xml/xml/366X_display_instance-bri.xml
/usr/local/cm/db/xml/xml/2811_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Extension_Mobility_Rules.xml
/usr/local/cm/db/xml/xml/Phone_7902_display_instance.xml
/usr/local/cm/db/xml/xml/7200_rules.xml
/usr/local/cm/db/xml/xml/BPS_Rules.xml
/usr/local/cm/db/xml/xml/vg204_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/366X_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/2811_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Product_496_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7941_display_instance.xml
/usr/local/cm/db/xml/xml/2801_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/2811_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/2911_display_instance-bri.xml
/usr/local/cm/db/xml/xml/269X_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Telepresence_TX9200_display_instance.xml
/usr/local/cm/db/xml/xml/Cat_4224_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/CAPF_dependencies.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/AMC_dependencies.xml
/usr/local/cm/db/xml/xml/Phone_7945_display_instance.xml
/usr/local/cm/db/xml/xml/Dragons_DMClient_display_instance.xml
/usr/local/cm/db/xml/xml/7905_display_instance.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/CTL_Rules.xml
/usr/local/cm/db/xml/xml/2851_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Product_501_rules.xml
/usr/local/cm/db/xml/xml/Phone_6945_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/1751_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/IAD_2420_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Phone_7937_rules.xml
/usr/local/cm/db/xml/xml/Phone_7937_display_instance.xml
/usr/local/cm/db/xml/xml/Product_496_rules.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_7970_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_1300_47_display_instance.xml
/usr/local/cm/db/xml/xml/ws-x6600_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/de30+_display_Instance-e1pri.xml
/usr/local/cm/db/xml/xml/TFTP_Display_Instance.xml
/usr/local/cm/db/xml/xml/Extension_Mobility_Display_Instance.xml
/usr/local/cm/db/xml/xml/Phone_7925_rules.xml
/usr/local/cm/db/xml/xml/Phone_9951_rules.xml
/usr/local/cm/db/xml/xml/2951_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/366X_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/1751_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Telepresence_500_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7921_rules.xml
/usr/local/cm/db/xml/xml/Phone_IP_Communicator_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/ATA_18x_rules.xml
/usr/local/cm/db/xml/xml/Product_467_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_9951_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-24_fxs_device.xml
/usr/local/cm/db/xml/xml/1760_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/2801_display_instance-bri.xml
/usr/local/cm/db/xml/xml/7920_display_instance.xml
/usr/local/cm/db/xml/xml/Cat_4224__display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/2951_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Cat_4000__display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/CTIManager_Display_Instance.xml
/usr/local/cm/db/xml/xml/commonphoneconfig.xml
/usr/local/cm/db/xml/xml/RIS_Data_Collector_Display_Instance.xml
/usr/local/cm/db/xml/xml/Phone_8945_display_instance.xml
/usr/local/cm/db/xml/xml/2821_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Product_520_display_instance.xml
/usr/local/cm/db/xml/xml/Product_513_display_instance.xml
/usr/local/cm/db/xml/xml/2901_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/7905_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/VGD-1T3_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/3725_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/ATA_187_display_instance.xml
/usr/local/cm/db/xml/xml/vg200_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/CCM_Rules.xml
/usr/local/cm/db/xml/xml/FC_VPN_Rules.xml
/usr/local/cm/db/xml/xml/Phone_7926_display_instance.xml
/usr/local/cm/db/xml/xml/as-8_display_instance-fxs_port_pots.xml
/usr/local/cm/db/xml/xml/3825_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/2951_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/dt-24+_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/2911_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/3825_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Phone_7941G-GE_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_200_rules.xml
/usr/local/cm/db/xml/xml/881VA-V_display_instance-bri.xml
/usr/local/cm/db/xml/xml/Phone_7936_rules.xml
/usr/local/cm/db/xml/xml/FC_CCD.xml
/usr/local/cm/db/xml/xml/dt-24+_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/WS-X6600_display_instance-adhoc_cfb.xml
/usr/local/cm/db/xml/xml/3825_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_7941_7961_rules.xml
/usr/local/cm/db/xml/xml/2851_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/CCM_Display_Instance.xml
/usr/local/cm/db/xml/xml/Phone_7971_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7931_rules.xml
/usr/local/cm/db/xml/xml/2801_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/1751_rules.xml
/usr/local/cm/db/xml/xml/3825_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Phone_7961G-GE_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_6941_display_instance.xml
/usr/local/cm/db/xml/xml/1751_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/iPhone_DMClient_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/ws-x6600_rules.xml
/usr/local/cm/db/xml/xml/FC_EMCC_Rules.xml
/usr/local/cm/db/xml/xml/vg200_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/364X_display_instance-bri.xml
/usr/local/cm/db/xml/xml/1760_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/c72xx_display_instance-t1_cas.xml
/usr/local/cm/db/xml/xml/Phone_6961_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7941G-GE_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/2821_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Phone_7945_7965_rules.xml
/usr/local/cm/db/xml/xml/CTL_provider_display_instances.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/AMC_Display_Instance.xml
/usr/local/cm/db/xml/xml/ICS77XX_MRP3-8FXS_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Product_503_display_instance.xml
/usr/local/cm/db/xml/xml/364X_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Android_DMClient_rules.xml
/usr/local/cm/db/xml/xml/2951_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/at-4_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Product_500_rules.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/2851_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/3845_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/ICS77XX_ASI160_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/269X_display_instance-bri.xml
/usr/local/cm/db/xml/xml/IAD_2420_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/1751_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/CiscoTelephonyCallDispatcher_Display_Instance.xml
/usr/local/cm/db/xml/xml/Telepresence_1300_47_rules.xml
/usr/local/cm/db/xml/xml/Phone_7940_7960_rules.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/2801_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/FC_FALLBACK.xml
/usr/local/cm/db/xml/xml/3925_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/WS-X6600_display_instance-app_control_cfb.xml
/usr/local/cm/db/xml/xml/nonios_gw_rules.xml
/usr/local/cm/db/xml/xml/IP_Phones_rules.xml
/usr/local/cm/db/xml/xml/366X_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Product_497_rules.xml
/usr/local/cm/db/xml/xml/Phone_3905_rules.xml
/usr/local/cm/db/xml/xml/881VA-V_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Cisco_WebDialer_Display_Instance.xml
/usr/local/cm/db/xml/xml/Phone_390_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/2811_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/FC_CCD_Rules.xml
/usr/local/cm/db/xml/xml/362X_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/CiscoTelephonyCallDispatcher_dependencies.xml
/usr/local/cm/db/xml/xml/ATA_187_rules.xml
/usr/local/cm/db/xml/xml/TAPS_Rules.xml
/usr/local/cm/db/xml/xml/Cat_4000__display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_7942_7962_rules.xml
/usr/local/cm/db/xml/xml/FC_B2BLINK.xml
/usr/local/cm/db/xml/xml/2901_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_7975_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_9971_rules.xml
/usr/local/cm/db/xml/xml/3925_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/dt-24+_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_6945_display_instance.xml
/usr/local/cm/db/xml/xml/2951_display_instance-bri.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-cfb.xml
/usr/local/cm/db/xml/xml/CBB_Display_Instance.xml
/usr/local/cm/db/xml/xml/Cat_4224_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/2901_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Phone_7962_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7971_display_instance.xml
/usr/local/cm/db/xml/xml/881VA-V_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/881VA-V_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_3951_rules.xml
/usr/local/cm/db/xml/xml/Phone_7961G-GE_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/BPS_Display_Instance.xml
/usr/local/cm/db/xml/xml/Cius_SP_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Product_497_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_1000_rules.xml
/usr/local/cm/db/xml/xml/3945_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/ws-x6600_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/ICS77XX_MRP2xx_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Phone_8941_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/269X_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/3725_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Product_491_display_instance.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_7936_display_instance.xml
/usr/local/cm/db/xml/xml/1861_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Product_499_rules.xml
/usr/local/cm/db/xml/xml/2801_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Product_503_rules.xml
/usr/local/cm/db/xml/xml/WS-X6600_display_instance-mtp.xml
/usr/local/cm/db/xml/xml/vgc_rules_-_phone.xml
/usr/local/cm/db/xml/xml/Telepresence_200_display_instance.xml
/usr/local/cm/db/xml/xml/Enterprise_Parameter_Rules.xml
/usr/local/cm/db/xml/xml/Cat_4224__display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/vgc_display_instance_-_phone.xml
/usr/local/cm/db/xml/xml/Cisco_Dirsync_Display_Instance.xml
/usr/local/cm/db/xml/xml/as-4_display_instance-fxs_port_pots.xml
/usr/local/cm/db/xml/xml/2911_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Telepresence_1100_display_instance.xml
/usr/local/cm/db/xml/xml/2921_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Phone_3951_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7941_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_1300_rules.xml
/usr/local/cm/db/xml/xml/2901_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/VGD-1T3_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_7942_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_6921_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/1751_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/usageprofile_display_instance.xml
/usr/local/cm/db/xml/xml/1861_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/2801_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/CMI_Rules.xml
/usr/local/cm/db/xml/xml/7905_rules.xml
/usr/local/cm/db/xml/xml/Phone_7965_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_8941_display_instance.xml
/usr/local/cm/db/xml/xml/Product_495_rules.xml
/usr/local/cm/db/xml/xml/MOHAudio_Translator_dependencies.xml
/usr/local/cm/db/xml/xml/Phone_6901_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/3745_display_instance-bri.xml
/usr/local/cm/db/xml/xml/Telepresence_1310_65_display_instance.xml
/usr/local/cm/db/xml/xml/3925_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/364X_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/RTMTReporter_Display_Instance.xml
/usr/local/cm/db/xml/xml/364X_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/iPhone_DMClient_rules.xml
/usr/local/cm/db/xml/xml/3945_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/CMI_Display_Instance.xml
/usr/local/cm/db/xml/xml/Telepresence_3000_display_instance.xml
/usr/local/cm/db/xml/xml/vg224_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Enterprise_Parameters.xml
/usr/local/cm/db/xml/xml/Phone_7985_display_instance.xml
/usr/local/cm/db/xml/xml/366X_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/3925_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/2811_display_instance-bri.xml
/usr/local/cm/db/xml/xml/2811_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Phone_7942_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Cius_rules.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Product_514_display_instance.xml
/usr/local/cm/db/xml/xml/Cius_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Cat_4224__display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/TVS_dependencies.xml
/usr/local/cm/db/xml/xml/2851_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/AMC_Rules.xml
/usr/local/cm/db/xml/xml/3745_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Phone_9971_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7970_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/TAPS_Display_Instance.xml
/usr/local/cm/db/xml/xml/CCM_dependencies.xml
/usr/local/cm/db/xml/xml/Cat_4000__display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Product_498_rules.xml
/usr/local/cm/db/xml/xml/DBLayerMonitor_Display_Instance.xml
/usr/local/cm/db/xml/xml/FC_B2BLINK_Rules.xml
/usr/local/cm/db/xml/xml/Phone_6961_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/2801_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/887VA-V_display_instance-bri.xml
/usr/local/cm/db/xml/xml/3945_display_instance-bri.xml
/usr/local/cm/db/xml/xml/881_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Product_495_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_500_32_display_instance.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Telepresence_500_32_rules.xml
/usr/local/cm/db/xml/xml/3745_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Phone_7921_display_instance.xml
/usr/local/cm/db/xml/xml/2911_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_7975_rules.xml
/usr/local/cm/db/xml/xml/Phone_7931_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Cat_4224__display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_8961_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/CBB_Rules.xml
/usr/local/cm/db/xml/xml/881_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/3845_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/366X_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/2951_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/1760_display_instance-bri.xml
/usr/local/cm/db/xml/xml/Telepresence_400_rules.xml
/usr/local/cm/db/xml/xml/VGD-1T3_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/887VA-V_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/2901_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Phone_7906_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_8961_rules.xml
/usr/local/cm/db/xml/xml/Cisco_IP_Manager_Assistant_dependencies.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/1861_display_instance-bri.xml
/usr/local/cm/db/xml/xml/3925E_display_instance-bri.xml
/usr/local/cm/db/xml/xml/MOHAudioTranslator_Display_Instance.xml
/usr/local/cm/db/xml/xml/Extension_Mobility_dependencies.xml
/usr/local/cm/db/xml/xml/Telepresence_500_rules.xml
/usr/local/cm/db/xml/xml/Phone_7925_display_instance.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-24_fxs_port_pots.xml
/usr/local/cm/db/xml/xml/2801_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/DBLayerMonitor_Rules.xml
/usr/local/cm/db/xml/xml/2901_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/2921_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/vg350_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/vg200_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/3925_display_instance-bri.xml
/usr/local/cm/db/xml/xml/ICS77XX_MRP3-8FXO-M1_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/ws-x6600_display_instance-fxs_port.xml
/usr/local/cm/db/xml/xml/Phone_6941_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Product_494_display_instance.xml
/usr/local/cm/db/xml/xml/ws-x6600_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Phone_6901_display_instance.xml
/usr/local/cm/db/xml/xml/26xx_display_instance-bri.xml
/usr/local/cm/db/xml/xml/364X_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/CTIManager_dependencies.xml
/usr/local/cm/db/xml/xml/VGD-1T3_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/2821_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/2921_display_instance-bri.xml
/usr/local/cm/db/xml/xml/2851_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Product_504_display_instance.xml
/usr/local/cm/db/xml/xml/Product_499_display_instance.xml
/usr/local/cm/db/xml/xml/CAPF_Display_Instance.xml
/usr/local/cm/db/xml/xml/1861_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/3825_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Cat_4000_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_3911_rules.xml
/usr/local/cm/db/xml/xml/1760_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/2921_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/362X_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/3725_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Telepresence_TX9000_rules.xml
/usr/local/cm/db/xml/xml/362X_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Product_500_display_instance.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Cat_4000_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/vg200_rules.xml
/usr/local/cm/db/xml/xml/ATA_18x_GARP.xml
/usr/local/cm/db/xml/xml/at-8_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_7940_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Cat_4224__display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/IP_Communicator_Rules.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/TFTP_dependencies.xml
/usr/local/cm/db/xml/xml/1760_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Phone_7902_rules.xml
/usr/local/cm/db/xml/xml/Dragons_DMClient_rules.xml
/usr/local/cm/db/xml/xml/IAD_2420_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Product_501_display_instance.xml
/usr/local/cm/db/xml/xml/Android_DMClient_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/362X_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Telepresence_1000_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7961_display_instance.xml
/usr/local/cm/db/xml/xml/3725_display_instance-bri.xml
/usr/local/cm/db/xml/xml/MITRA_Rules.xml
/usr/local/cm/db/xml/xml/2821_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Product_471_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_894x_rules.xml
/usr/local/cm/db/xml/xml/vg200_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/3845_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/1760_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Product_494_rules.xml
/usr/local/cm/db/xml/xml/Telepresence_3000_rules.xml
/usr/local/cm/db/xml/xml/366X_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Cisco_Messaging_Interface_dependencies.xml
/usr/local/cm/db/xml/xml/ws-x6600_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/vg200_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Product_513_rules.xml
/usr/local/cm/db/xml/xml/1751_display_instance-bri.xml
/usr/local/cm/db/xml/xml/2851_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_7960_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/RIS_Data_Collector_Rules.xml
/usr/local/cm/db/xml/xml/Phone_3911_display_instance.xml
/usr/local/cm/db/xml/xml/vg202_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/2821_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_7906_rules.xml
/usr/local/cm/db/xml/xml/Phone_390_rules.xml
/usr/local/cm/db/xml/xml/dt-24+_display_instance-t1cas_port_ls.xml
/usr/local/cm/db/xml/xml/364X_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/ICS77XX_MRP3-16FXS_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/888_display_instance-bri.xml
/usr/local/cm/db/xml/xml/269X_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/CTIManager_Rules.xml
/usr/local/cm/db/xml/xml/Phone_Analog_rules.xml
/usr/local/cm/db/xml/xml/Telepresence_TX9200_rules.xml
/usr/local/cm/db/xml/xml/Product_493_rules.xml
/usr/local/cm/db/xml/xml/2901_display_instance_e1r2.xml
/usr/local/cm/db/xml/xml/3845_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Phone_7912_display_instance.xml
/usr/local/cm/db/xml/xml/c72xx_display_instance-t1_pri.xml
/usr/local/cm/db/xml/xml/2921_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/3725_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_7912_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/1760_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/2951_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Phone_7975_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/Cisco_WebDialer_dependencies.xml
/usr/local/cm/db/xml/xml/3745_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-t1cas_port_ls.xml
/usr/local/cm/db/xml/xml/vg200_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/c72xx_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/CBB_dependencies.xml
/usr/local/cm/db/xml/xml/CDR_Insert_dependencies.xml
/usr/local/cm/db/xml/xml/3845_display_instance-bri.xml
/usr/local/cm/db/xml/xml/TVS_Display_Instance.xml
/usr/local/cm/db/xml/xml/2911_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Phone_7985_rules.xml
/usr/local/cm/db/xml/xml/3825_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/2901_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Telepresence_274_rules.xml
/usr/local/cm/db/xml/xml/1751_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/3925_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/3945_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Product_493_display_instance.xml
/usr/local/cm/db/xml/xml/2821_display_instance-bri.xml
/usr/local/cm/db/xml/xml/Product_502_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_400_display_instance.xml
/usr/local/cm/db/xml/xml/Cisco_DirSync_Rules.xml
/usr/local/cm/db/xml/xml/vg200_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Product_502_rules.xml
/usr/local/cm/db/xml/xml/Telepresence_display_instance.xml
/usr/local/cm/db/xml/xml/2851_display_instance-bri.xml
/usr/local/cm/db/xml/xml/1760_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Phone_Analog_SCCP_display_instance.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Phone_6945_rules.xml
/usr/local/cm/db/xml/xml/Telepresence_TX9000_display_instance.xml
/usr/local/cm/db/xml/xml/Cisco_DirSync_Dependencies.xml
/usr/local/cm/db/xml/xml/CiscoTelephonyCallDispatcher_Rules.xml
/usr/local/cm/db/xml/xml/as-2_display_instance-fxs_port_pots.xml
/usr/local/cm/db/xml/xml/2951_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/1861_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_7910_rules.xml
/usr/local/cm/db/xml/xml/269X_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Product_498_display_instance.xml
/usr/local/cm/db/xml/xml/2921_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Product_504_rules.xml
/usr/local/cm/db/xml/xml/2921_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/ICS77XX_MRP3xx_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/FC_VPN.xml
/usr/local/cm/db/xml/xml/35xx_rules.xml
/usr/local/cm/db/xml/xml/3825_display_instance-bri.xml
/usr/local/cm/db/xml/xml/Phone_E20_display_instance.xml
/usr/local/cm/db/xml/xml/269X_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/Phone_7960_display_instance.xml
/usr/local/cm/db/xml/xml/3745_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/3845_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_7910_display_instance.xml
/usr/local/cm/db/xml/xml/at-2_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Cisco_IP_Voice_Media_Streaming_App.xml
/usr/local/cm/db/xml/xml/dt-24+_display_instance-t1cas_port_gs.xml
/usr/local/cm/db/xml/xml/362X_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/e1_r2_2901_rules.xml
/usr/local/cm/db/xml/xml/Product_491_rules.xml
/usr/local/cm/db/xml/xml/FC_FALLBACK_Rules.xml
/usr/local/cm/db/xml/xml/2811_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/2901_display_instance-bri.xml
/usr/local/cm/db/xml/xml/362X_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/3725_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Product_520_rules.xml
/usr/local/cm/db/xml/xml/3845_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Telepresence_1300_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7912_rules.xml
/usr/local/cm/db/xml/xml/Phone_6921_6941_6961_rules.xml
/usr/local/cm/db/xml/xml/Cat_4000__display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/2851_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/3745_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Common_rules.xml
/usr/local/cm/db/xml/xml/3945_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/ICS77XX_ASI81_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/3725_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/3745_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/888_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/269X_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/MOHAudioTranslator_Rules.xml
/usr/local/cm/db/xml/xml/ws-x6600_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_7965_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/enterprisephoneconfig.xml
/usr/local/cm/db/xml/xml/c72xx_display_instance-t1_cas_port_em.xml
/usr/local/cm/db/xml/xml/Cisco_WebDialer_Rules.xml
/usr/local/cm/db/xml/xml/Phone_6911_display_instance.xml
/usr/local/cm/db/xml/xml/364X_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/Cat_4000_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/Phone_7945_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/CTL_dependencies.xml
/usr/local/cm/db/xml/xml/Phone_8945_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/2821_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_IP_Communicator_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_7961_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/366X_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/362X_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/3925_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/35xx_display_instance-vcb.xml
/usr/local/cm/db/xml/xml/TVS_Rules.xml
/usr/local/cm/db/xml/xml/TFTP_Rules.xml
/usr/local/cm/db/xml/xml/26XX_display_instance-bri.xml
/usr/local/cm/db/xml/xml/3945_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_E20_rules.xml
/usr/local/cm/db/xml/xml/Phone_6921_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_3200_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_UnifiedPersonalCommunicator_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_1310_65_rules.xml
/usr/local/cm/db/xml/xml/3945_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-bri.xml
/usr/local/cm/db/xml/xml/cat6000_display_instance-mtp.xml
/usr/local/cm/db/xml/xml/3845_display_instance-t1cas.xml
/usr/local/cm/db/xml/xml/Phone_7911_SIP_display_instance.xml
/usr/local/cm/db/xml/xml/3945E_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/2911_display_instance-t1pri.xml
/usr/local/cm/db/xml/xml/Cisco_IP_Voice_Media_dependencies.xml
/usr/local/cm/db/xml/xml/Product_471_rules.xml
/usr/local/cm/db/xml/xml/2811_display_instance-fxo_port_gs.xml
/usr/local/cm/db/xml/xml/1861_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/2911_display_instance-t1cas_port_em.xml
/usr/local/cm/db/xml/xml/2911_display_instance-e1pri.xml
/usr/local/cm/db/xml/xml/3925_display_instance-mgcp.xml
/usr/local/cm/db/xml/xml/Phone_7962_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_6901_6911_rules.xml
/usr/local/cm/db/xml/xml/Telepresence_1100_rules.xml
/usr/local/cm/db/xml/xml/Cius_SP_rules.xml
/usr/local/cm/db/xml/xml/ICS77XX_MRP2XX_display_instance-bri.xml
/usr/local/cm/db/xml/xml/Phone_7926_rules.xml
/usr/local/cm/db/xml/xml/7920_XML_Rules.xml
/usr/local/cm/db/xml/xml/Phone_3905_display_instance.xml
/usr/local/cm/db/xml/xml/Phone_UnifiedPersonalCommunicator_Rules.xml
/usr/local/cm/db/xml/xml/WS-X6600_rules-media.xml
/usr/local/cm/db/xml/xml/Phone_7940_display_instance.xml
/usr/local/cm/db/xml/xml/Telepresence_3200_rules.xml
/usr/local/cm/db/xml/xml/881_display_instance-fxo_port_ls.xml
/usr/local/cm/db/xml/xml/Phone_TANDBERG_rules.xml
/usr/local/cm/db/xml/xml/Phone_7970_7971_rules.xml
/usr/local/cm/db/xml/xml/2821_display_instance-t1pri.xml
/usr/local/cm/idp/
/usr/local/cm/idp/IDP
/usr/local/cm/idp/idp/
/usr/local/cm/idp/idp/IDP
/usr/local/cm/idp/idp/idp/
/usr/local/cm/idp/idp/idp/IDP
/usr/local/cm/idp/idp/idp/idp/
/usr/local/cm/idp/idp/idp/idp/IDP
/usr/local/cm/idp/idp/idp/idp/idp/
/usr/local/cm/idp/idp/idp/idp/idp/IDP
/usr/local/cm/idp/idp/idp/idp/idp/idp/
/usr/local/cm/idp/idp/idp/idp/idp/idp/IDP
/usr/local/cm/idp/idp/idp/idp/idp/idp/idp/
/usr/local/cm/idp/idp/idp/idp/idp/idp/idp/IDP
/ccm/DialPlan/
/ccm/DialPlan/NANP
/usr/local/cm/db/replicates.txt
/usr/local/cm/db/DBPerfMon.xml
/usr/local/cm/db/dblenv.bash
/etc/services
/etc/odbc.ini
/usr/local/cm/db/informix/etc/sqlhosts
/home/informix/.rhosts
IBM Informix Dynamic Server Version 11.50.UC8X7 -- On-Line -- Up 00:09:30 --   263344 Kbytes
Service Manager is running
A Cisco DB[STOPPING]
Commanded Out of Service
A Cisco DB[NOTRUNNING]
----> END Standard Output
----> BEGIN Standard Error
bad decrypt
13130:error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad   decrypt:evp_enc.c:330:
Physical restore failed - function read archive backup failed code 1 errno 0
----> END Standard Error
This led to a TAC case and two hours of troubleshooting. Many questions about the security password (you can get a bad decrypt if the original and new passwords are different, but on 8.6.2 it prompts you for the new/old password on restore attempt) and also about the hostname and IP address being identical between the backup and the location I was trying to restore to.
Overall, we found that the above message was caused by either a corrupted backup (coming from the lab server) or a corrupted restore (it kept failing on the ccmdb part).
The fix was to take a fresh backup (I used SolarWinds SCP/SFTP, which is free, for both backup and restore) and do an immediate restore to fresh system.
Hope this helps someone, because through all my research, I never found anything like it.
Mohammed Khan
Thanks for posting. I am sure this may help for some one who encounter similar issue.
Mohammed Noorulla Khan
ahochau_2
Just had the exact same problem with the restore.  It appears the host name is case sensitive.  Rebuilt the server with the same ip but changed the host name from CUCM1 to ipsprdcucm1 and I was able to do the full restore.  CUCM1 is what the restore process showed for the server.
