Basic IVR license on ISR4000
Dear,
I have a router ISR4331/K9 , it has the following license:  UCK9. This routers received the calls over its interface lan and send the calls to E1 interfaces connected to Avaya PBX.
We will want to add a basic IVR: press 1 ...., press 2....
Do I need other license? o can i use TCL programing ?
George Sotiropoulos
The following link will help you
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel9_0/install/cue_install_book/cue_virtual_licensing.html
You better proceed first with the evaluation licenses and then work on purchasing, based on what are you actual needs.
It is recommended that you install and activate the permanent licenses before the expiration of your evaluation licenses. From Cisco Unity Express Virtual 9.0.2 Release onwards, you do not need to install permanent license.
SUMMARY STEPS
    1.    show license evaluation
    2.    license activate voicemail mailboxes
    3.    license activate ports
    4.    license activate ivr sessions
    5.    reload
    6.    show license in-use
Hope this helps,
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
George Sotiropoulos
SUMMARY STEPS
    5.    reload
Hope this helps,
George
