06-02-2014 12:40 PM - edited 03-16-2019 10:58 PM
Hi all,
We are planning to implement IP telephony in our network. We have 106 users. We are planning to buy 1 CUCM BE6k, 3 POE switches and a voice gateway.
What are the required licenses? we need the basic call routing only (dont want to use video, uccx, etc.)
Is another BE6k server required for redundant SUB?
Any help will be appreciated
Thanks in advance
06-02-2014 01:12 PM
You'll only need CUWL licenses for each user. CUCM licensing no longer cares about node count.
Another BE6k will work and you can build it out as a subscriber node or you could just use any hardware you want as long as it meets the guidelines.
06-03-2014 05:37 AM
Hi Bran,
Thanks for your reply.
Can you tell me the names of the licenses we require so that we can give the order.
06-03-2014 10:35 AM
Hi Fayiz,
you can refer the Q & A link of BE 6K .You can get info Under Licensing Options
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/qa_c67-703226.html
regds,
aman
06-03-2014 10:41 AM
You'll want to work with a Cisco partner to make sure you get thr right licenses for your environment.
06-04-2014 12:13 AM
Hi Brian,
Will the CUWL license support voicemail?
