BE6 ESXi upgrade to 6.7 from 5.5
sprintership-il
Question: does the Virtual Machine hardware should be updated after upgrade from 5.5 to 6.7?
No it says:  Compatibility ESXi 5.0 virtual machine and seems like all is working fine but not sure if it should be upgraded to 6.X
b.winter
It depends on the CUCM version you are running. E.g. CUCM 12.5 needs VMV 13.
b.winter
Please find more information here:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/cisco-collaboration-virtualization.html
Also, the OVA filename gives you a hint on that e.g. "cucm_12.5_vmv13_v1.0.ova"
--- Please rate this post as "Helpful" or accept as a solution, if your question has been answered ---
