Best software for CDR report analysis
Debabrata Majhi
HI,
Could you please help me to analysis  which is the best software for CUCM CDR report .
Debabrata Majhi
10 Replies 10
Aman Soi
Hi Majhi,
you can have a look into Variphy.
http://www.variphy.com/products/enterprises/cisco-call-history-reporting
regds,
aman
We use software called PhoneControl Weblink. Very detailed and customisable.
www.phonecontrol.com.au
Cheers
Ben
Cisco Prime Collaboration Assurance is another, check below data  sheet link
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-collaboration/datasheet-c78-733113.html
HTH,
Mohammed Noor
We got the downlink link after reguster.We will let you know the status ASAP
Mustafa DURAN
You may also check IPERA Communication Suite. Provides 400+ drill-down reports for various purposes including Call Accounting, Expense Management, Call Analysis, Resource Utilization Analysis (Trunk/Gateway), etc.
For more information visit iperamea.com
MD
Cisco Compatible Billing and Call Management Software
http://www.connectps.com/cisco-xml-services-for-ip-phone.htm
Reza Mousavi
mikecotrone
Call Record Analyzer is a newer cloud based CDR/CMR reporting/troubleshooting tool that has great visual scheduled reporting, Call Transfer tracer that visualizes crazy call transfers call leg by leg, and location based visualizations for troubleshooting QOS related issues from phone in a specific CAC region vs. the Cube GW vs. the UCM cluster.
Call Record Analyzer (CRA) Website
VoIP Engineer
Another option would be VoIP Detective.  We offer a free version as well as a PRO version.  It includes CDR reporting, UCCX wallboard, CUBE analytics and more.
