So I'm really not a voice expert but manage a voice system and have spent my day trying to figure out how to block toll fraud from our phone system. I was thinking of using a voice translation-rule to block outgoing called numbers that match the area code of numbers like 242 Bahamas that don't require an international code to dial apparently.
1. Is there a better way that I should explore, other than using a voice translation something like this:
voice translation-rule 5
rule 1 reject /242/
rule 2 reject /264/
rule 3 reject /284/
voice translation-profile BLOCK-TOLL-FRAUD
translate called
dial-peer voice X pots
call-block translation-profile outgoing BLOCK-TOLL-FRAUD
call-block disconnect-cause outgoing call-reject
2. If a voice translation-rule is suitable, can I use [ ] for my rules to help since there are more numbers than available rules. Such as: rule 1 reject /24[26]/
Would appreciate help!
Yes translation patterns with reject are probably easier that using router patterns using caller ID to block.
there is a rule limitation you might bump into if you have a large number of calls to block, but if its just calls like Bahamas, then you should be fine.
Just to clarify, you mean "translation pattern" or "route pattern"? I had considered blocking on a route pattern.
Should I be considering another option. Is there a better way to block it on the inbound?
I found this https://supportforums.cisco.com/t5/ip-telephony/translation-rule/td-p/2894460 but wasn't sure I understood it fully. It seems it's preventing null patterns, patterns starting with a 9 (to prevent sending a pattern that would be routed back out), correct? But how does the Block all not keep you from receiving any calls (is it because it's a dial-peer with lower priority?)
Thanks for the input
Thanks all for your input. I ended up created Block Route Patterns for each of the area codes in CM. Seems to have taken care of the issue or slowed it down significantly.
