02-15-2012 03:01 AM - edited 03-16-2019 09:36 AM
I've been trying to think of an efficient way to shun or divert incoming calls if the caller has their caller-ID blocked or withheld. I have this setup in a working home environment (lab).
The problem I have is, how can I match on *nothing*? I thought about a translation rule to match the calling number, but if there is nothing there then how is that possible?
Currently, I pay my telco to block callers of this type. Therefore I am unable to call the system and block my ID to see what is actually sent (i.e. simply nothing or something else such as "withheld" as a name field for example.
This system is connected to a PSTN POTS trunk via a single FXO port.
Thanks for any suggestions. I were unable to find someone else online that has done this.
02-15-2012 03:14 AM
Blocks no ANI calls:
voice translation-rule 1
rule 1 reject /^$/
voice translation-profile reject_ANI translate calling 1
dial-peer voice 1 pots call-block translation-profile incoming reject_ANI
call-block disconnect-cause incoming user-busy
Note when doing that, you will be unable (for example), to receive calls from Skype users, and other legitimate callers.
06-05-2012 06:47 AM
Thanks Paulo,
I'm now going to be able to put this to the test. I ran a quick test and when you withheld a number the calling number is blank but the calling name is "WITHHELD".
I'm wondering if it is possible to match on a calling name? Because with the above method, when international callers phone us there is no sent calling number but the calling name is "INTERNATIONAL", , so the above would also block internation callers?
002710: Jun 5 12:28:42.993 GMT: [0/0/0] get_fxo_caller_id calling num= calling name=WITHHELD calling time=06/05 12:28 number blocked
I've included our output to show
01-24-2014 08:37 AM
I am wondering if you got this working fully in the end Tony?
If so, how di dyou accomplish this task.
Rgrds,
Neil
03-04-2014 08:25 PM
Unfortunately not. I ended up moving home and circumstances changed. CUCME has some unfortunate and annoying limitations.
