Block incoming calls
bschnelle
is there a way to block incoming calls using call manager v6.1.3?
Gregory Brunn
Better question what are you dong running 6.1.3?  Time for an upgrade my friend.
You can do it in CUCM 8.0 by routing next hop by calling party number if you are using MGCP.
If you are using H.323 or SIP you could just set up a translation pattern and use the call-block command on the dial-peer.
