Block outbound call on MSTeams
shahulhameed
Level 3
Level 3
Dear Friends,
The MSTeam has integrated with CUCM 12.5. Both IP phone and Teams are ringing simultaneously for incoming calls and able to answer on both ends. The manager wants to block outgoing calls from Teams and only allow from the IP Phone. I have tried the below steps but no luck.
01. I have created a partition and CSS to block outgoing calls. It is blocked on IP phone only but the user able to call from Teams.
02. I blocked the route pattern under the Route Pattern even though the outgoing call is working from Teams
03. Uncheck the PSTN access and outbound calls under the SIP Trunk for Teams. But no luck.
Please advise. How to block outbound calls on Teams?
2 Accepted Solutions
If you want to control incoming calls to a directory number you would need to put the directory numbers in a partition that is seen only by whoever that should be able to make a call to the directory number. For outbound calls you’ll control that by what partitions that you make available in the calling search space of the device that makes the the call.
Response Signature
I see. Thanks for the clarification. Likely due to English not being your first language you where not very clear in what you wrote. You actually wrote that there is a delay for 4-5 rings before the call rings the IP phone and then it reaches Teams after an undefined time. See the screenshot where I have marked the various parts to make it clearer.
That said have you verified that there is no delay defined on your RD/RDP combo? As an example see this screenshot where there is a 4 second delay before the call will ring to the defined remote destination number.
Response Signature
32 Replies 32
Lock2
MyGiftCardSite
Using the Microsoft Teams admin center
In the left navigation, select Users, and then select the display name of the user from the list of available users. Next go to Audio Conferencing, select Edit. Under Dial-out from meetings, select the dial-out restriction option you want. Select Save.
Lock2
Can you please explain how you have configured the integration on the CM end? Are you using Mobile Connect features for the same time ringing on the two platforms?
Response Signature
Scott Leport
Level 7
Level 7
You want to stop outgoing calls from MS Teams?
Surely the more optimal solution would be disabling the Enterprise Voice functionality from the user(s) in Teams as opposed to reconfiguring CUCM?
Not very into how calling works on the MS platform, but wouldn’t what you suggest also turn off the ability to receive inbound calls?
Response Signature
Yeah, that’s a fair point Roger. I was going for the quick win! ‘:-)’
Maybe the OP could look at some voice routes / PSTN usage type config on Teams as documented here:
https://ipcorp.co.uk/microsoft-teams-dial-plan/
As you rightly said, we need more info on the integration end to end. I am particularly interested in how CUCM fits into this when making outgoing calls from MS Teams.
When we evaluated Teams calling in integration with our CM system we used Mobile Connect to get both sides to ring simultaneously. That’s why I asked if the OP also used that for their integration.
With Mobile Connect functionality and the fact that it does a reverse call anchor for calls that originates from the remote destination number of the remote destination profile or from the mobile identity remote destination number if TCT/BOT/TAB type of devices are used for the integration you can control where it can call by the device CSS. If the call is properly identified as coming from the remote destination number it will honour the restriction(s) set by the CSS on the MC device.
This is often overlooked as the calling number might not make a match and therefore not anchor the call to the MC device.
This is in essence a matter of having correct configuration so that the calling number matches what is defined on the remote destination number.
My personal preference is to make the needed adjustment on the SBC(s) that integrates the two disparate systems so that the calling number that egress the SBC to CM makes a match.
Response Signature
shahulhameed
Level 3
Level 3
Hello Roger\Scott,
Thanks for your response. Yes, I have enabled the Mobility service. So it's ringing simultaneously. MsTeams handling by infra team. So, I would like to have full control of the end users calls. Is it not possible to block from CUCM or PSTN VG?
@shahulhameed I described how you can do what you ask about in CM. If there was something unclear in my answer please ask for specifics on that part and I’ll try to explain that in more details.
Response Signature
Hello Roger,
Its clear. I got it.
Thanks lot
To add to my previous answer I would recommend you to use the older style of Mobile Connect configuration with RDP and RD, instead of the newer option where the Webex/Jabber mobile device (TCT/BOT/TAB) has a Mobile Identity, as that would impose the calling restriction onto these devices as well, ie not just for the Teams client, and that might not be what you want. If you isolate the integration for Teams to use the RDP and RD combination you’ll have the possibility to put the restriction on this alone as you can set the CSS on the RDP to something that restricts the calls to what you want.
Please have in mind that there are two configuration values on a RDP that has the word CSS in it, CSS and Redirecting CSS. The later is used for routing calls to the remote destination number on the RD and the former is what controls where you can call to from the RDP “device” when the call is identified as coming from the remote destination number.
Response Signature
Would you be able to share with me the steps for configuring RDP & RD for MS Teams?
As there is not one way for how this can be setup it would be better if you where to share how your Mobile Connect configuration for the integration looks like so that I can make specific suggestions on how to configure the RDP and RD. In general you can follow any configuration guide for how to configure RDP and RD, just set the Reroute CSS to point to your SBC(s) that integrates with the Microsoft Teams calling platform. For the calling part I’ve already outlined what you’d need to do to make the call anchor on the RDP so that it uses the CSS set on the RDP.
Response Signature
01. Enable Mobility under End User Configuration at Mobility Information.
02. Created Remote Destination Profile under Device - Device Setting - Remote Destination Profiles
03. Configured Remote Destination under Device
04. Created route pattern - added 8 as a prefix with user extension
04. Created SIP-TRUNK to our Domain AD with the above route pattern
Great, thank you! So by the look of it you have the basics of the whole setup in place. If I understand you correctly you add the prefixed 8 on the RP? I would recommend you to do this already on the RD number and have the RP match the 8 + the number. What you then need to do is to make sure that the calling number from Teams comes into CM with the prefixed 8 so that it matches with the number on the RD. By this it will anchor the call to the RDP and use the CSS that you have configured the RDP to use. Adding the 8 is easily done in the SBC as it traverses it on its way to CM. There is not more to it than that.
Response Signature
