08-22-2021 01:38 AM
hi
I created a call handler in Cisco Unity Connection Version 11.5.1.10000-6 and its working fine I need to prevent or block some extensions from been called from user input
Solved! Go to Solution.
08-22-2021 02:36 AM - edited 08-22-2021 02:36 AM
You can use unity restriction table to block call transfer from unity to some extension .
Refer below Link for how to use Unity restriction table.
https://www.ciscopress.com/articles/article.asp?p=2021962&seqNum=4
08-22-2021 03:17 AM
thank's a lot it's working with the Unity restriction table.
