Block the specific number about external incoming call for specific Directory Number
wilsonsant
Level 6
Level 6
Hi Guys,
The Customer have the solution with CUCM 11.x and H323 Gateway. He would like to block the external incoming call (PSTN specific number)  for a one specific directory number.
Example:
External Number YY112166xxxx
Directory Number 7xxx
The Customer need that only the directory number 7xxx reject call of number YY112166xxx. Is it possible?
Wilson
Here's an example:
voice translation-rule 1
rule 1 reject /1121161234/
voice translation-profile call_block
translate calling 1
dial-peer voice 1 pots
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
incoming called-number 7000
This assumes your carrier is sending 4 digits for called number
Brandon
5 Replies 5
Brandon Buffin
Yes, this is possible. How are calls being routed to 7xxx? Direct dial to an external number or through an operator. If direct dial, use a voice translation rule on the gateway to block the call. Apply the translation profile to an inbound dial peer specific to the DID for this extension.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con13
Brandon
Hi Brandon,
Thanks lot for Your contact and sorry by delay in answer. I read the procedure, is clear for me who to configure for all Directory Number reject the specific external number call, but, I don´t understand who to do for specific directory number. Do You have any models for pass to me, please.
Wilson
Here's an example:
translate calling 1
Brandon
Hi Brandom,
I will request for my Customer apply the configuration then I inform to You about results.
Wilson
Hi Brandom,
The Customer apply the configuration and worked fine.
Thanks a lot,
Wilson
