Blocking Calls from specified ANI number
cevliyaoglu
Hi all,
I want to block  some calls for some ANI numbers.   Our CUBE has several SIP connections to different devices
Calls come from Telco SPCUBE to our cube and then it goes to either  CVP or CUCM
Here are dial peers and translation rules
I created voice otranslation rule 999 and voice translation-profile call_block below.
  1. Can somebody help me about how to add dial-peer configuration to refer these blocking  rules
********** config deleted for security reasons**************
Hmm, this behaves differently than I remember.  Try this:
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
On each dial-peer (of course, test it with one first).  What I don't know is if that will interfere with the normal translation-profile.  I don't think it will, but if there is a conflict, the CLI will likely tell you when you try to enter it.
FYI: I found this in this document: http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con13
7 Replies 7
Brandon Pierce
Level 4
Level 4
Normally you would just add the incoming blocked translation rule to your incoming dial-peer.
Hi Brandon Yes but how?  Do I need to add new dial peer or modify the existing ones?
Just modify the existing one.  Just make sure you are not opening holes or closing call routing paths for your existing call rules.
Example:
dial-peer voice 29 voip
 translation-profile incoming FXS29
The problem is that most of your inbound dial-peers already have translation-profile and only one translation profile can be applied to a dial-peer in each direction.  I think you will need that add the 'translate calling 999' command to each 'IN' translation profile.
Well,  I couldn't do this, If I modify the existing one, then I think the translation profile will change on the dial peer. So,  the old translation profile will be removed. In this case the other translation rule will not work.And it will effect to whole calls.
How is it possible to add this blocking rule , so that CUBE,  will check the dial peer  and block the ANI number if needed,but other calls will work properly.
Isn't it possible?
Hi Chris
It worked as you suggested yesterday. I added
to my all incoming dial peers  And it worked properly
Thanks a lot.
