02-28-2011 05:08 AM - edited 03-16-2019 03:40 AM
Hi Guys,
My Customer have a solution with 02 CallManager version 5.1.3. The scenario is 02 Gateway with 08 E1´s each, working the MGCP Protocol and ISDN QSIG. He Would You Like know if is possible block collect call. I remember that the 04 years ago I reaserched and not was possible to do. Today is possible?
Thank You,
Wilson
Solved! Go to Solution.
02-28-2011 07:35 AM
AFAIK there is none.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-28-2011 07:16 AM
If you mean block incoming calls with MGCP the answer remains the same, not possible.
Blocking calls based on ANI needs to be done with H323.
java
02-28-2011 07:31 AM
Javalenc thank You for your answer. I passed this information to my Customer, but, He would like know if there is any documentation about this. I searched this information in Cisco site, but, didn´t find. Could you help me,
Thank You very much,
Wilson
02-28-2011 07:35 AM
java
