Blue wallpaper
i15
Hi.
I got 8861-3pcc, but it does not have this nice looking blue background:
Is it possible to download it from somewhere?
Thank you.
Yeah, that image is not something you can just download from the device, it's built directly into the firmware of the device.
java
if this helps, please rate
5 Replies 5
Jaime Valencia
Because that is a picture from a phone with enterprise FW, not a 3PCC model like the one you have.
java
Thank you.
That is right. I just thought someone can share it from their phones :)
java
bijpraka
Yeah. Its built in the firmware. However you can download any royalty free blue image and use it as a wallpaper.
This should come close:
https://images.pexels.com/photos/281260/pexels-photo-281260.jpeg?auto=compress&cs=tinysrgb&dpr=2&h=650&w=940
Thanks.
HARIS_HUSSAIN
You have to use any blue image and customize it to fit the 8861 Phone and set it as your background.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
