Bogen TAMB supervisory disconnect?
Jason Aarons
Level 6
Level 6
Customer has a Bogen TAMB2 paging system integrated with CUCM 8.5.1.  The paging works, but not all the time, more like 50% of the time it will work and 50% of the time it will not.  It seems like the calls do not always disconnect from the paging system.  Does anyone have any experience with these systems having this problem?
It is currently going out an FXO port on the voice gw (2951 with pvdm3-64)
Anyone have recommended jumper settings for the Bogen TAMB?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.03.14 16:07:55 =~=~=~=~=~=~=~=~=~=~=~=
term mon
culmvoipgw1#terr m len 0
culmvoipgw1#
001038: Mar 14 22:08:10 MEZ: htsp_timer_stop3
001039: Mar 14 22:08:10 MEZ: htsp_timer_stop3
001040: Mar 14 22:08:10 MEZ: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.htsp_setup_req
001041: Mar 14 22:08:10 MEZ: htsp_process_event: [0/2/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
001042: Mar 14 22:08:10 MEZ: [0/2/0] set signal state = 0xC timestamp = 0
001043: Mar 14 22:08:10 MEZ: htsp_timer - 500 msec
001044: Mar 14 22:08:11 MEZ: htsp_process_event: [0/2/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
001045: Mar 14 22:08:11 MEZ: htsp_timer_stop2
001046: Mar 14 22:08:11 MEZ: htsp_process_event: [0/2/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
001047: Mar 14 22:08:11 MEZ: htsp_process_event: [0/2/0, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_alert
001048: Mar 14 22:08:11 MEZ: htsp_timer - 350 msec
001049: Mar 14 22:08:11 MEZ: htsp_process_event: [0/2/0, FXOLS_WAIT_CUT_THRU, E_HTSP_EVENT_TIMER]fxols_handle_cut_thru
001050: Mar 14 22:08:11 MEZ: htsp_timer_stop
001051: Mar 14 22:08:15 MEZ: htsp_timer_stop3
001052: Mar 14 22:08:15 MEZ: htsp_process_event: [0/2/0, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
001053: Mar 14 22:08:15 MEZ: htsp_timer_stop
001054: Mar 14 22:08:15 MEZ: htsp_timer_stop2
001055: Mar 14 22:08:15 MEZ: htsp_timer_stop3
001056: Mar 14 22:08:15 MEZ: [0/2/0] set signal state = 0x4 timestamp = 0
001057: Mar 14 22:08:15 MEZ: htsp_timer - 2000 msec
001058: Mar 14 22:08:15 MEZ: htsp_process_event: [0/2/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
001059: Mar 14 22:08:17 MEZ: htsp_process_event: [0/2/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
001060: Mar 14 22:08:17 MEZ: htsp_process_event: [0/2/0, FXOLS_ONHOOK, E_DSP_SIG_0100]u all
All possible debugging has been turned off
adam.caggiano
Hi Jason,
http://www.bogen.com/products/pdfs/telephonepagepdfs/TAMB2m.pdf
Here's the manual... on page 5 or 6 you will see the dip switch info.
Is the 2951 port configured to loop start or ground start, and does this match on the dip switch?
Is it set to Trunk instead of Station?
Look also under the important note on "Station Access", do you need VOX timer and CPC turned off? (set to "1")
Cheers,
Adam
adam.caggiano
Just noticed... you are getting DSP errors with your pvdm3-64, is there enough available DSPs for all your voice ports?
