Branch mobile calls through HQ E1
jacobwminja90
Help on how to direct branch calls to use HQ E1 for mobile calls, i have tried to direct it via Local route group to HQ gateway without success,
I have branch and hq which are on different locations, I want mobile calls from branch to be routed to hq via sip trunk and I want to use e1 for outgoing&incoming mobile calls
5 Replies 5
Devansh
could you please elaborate you question. are you trying to send the HQ calls via E1 using Mobile calls. are you using different E1 for other calls?.
The incoming part, you'll have to work that out with your telco, that's not something you control.
The outbound part, is as Jitender explained, this is CSS/partitions and a RP/RG, are you sure you're hitting the right route pattern?
java
if this helps, please rate
Jitender Bhandari
Sounds straightforward to me.
1) Create a Route Pattern to match the mobile number.
2) Create a Route List and a Route Group.
3) Put the remote Gateway in the Route Group and Put the Route Group in the Route List.
4) Point the Route Pattern create in Step 1 to Route List created in Step 2
(Rate if it helps)
JB
I have tried that still the same problem
