03-29-2017 05:02 AM - edited 03-17-2019 09:55 AM
Hi folks,
Problem description: When US Customer Mobile no plays voicemail message to agent, we hear 4 DTMF tones are passed.
Am facing weird issue on US customers. I have captured Voice Gateway q931 ISDN logs, ccapi, ccsip messages. In logs unable to trace out.
I suspect in logs is
1. Fax Rate=FAX_RATE_VOICE(0x2)
2. Consume mask is not set. Relaying digit. Check DTMF relay digit end for 3way conf.
3. STOP tone on digit = FALSE.
458185 - Source CCAPI call id, 458186 - CCAPI destination call id.
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575066: 1076657: Mar 28 2017 19:39:34.227: //458186/21305700000B/CCAPI/cc_api_call_digit_end:
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575067: Consume mask is not set. Relaying Digit 4 to dstCallId 0x6FDC9
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575068: 1076658: Mar 28 2017 19:39:34.227: //458186/21305700000B/CCAPI/cc_relay_digit_end_for_3way_conference:
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575069: Check DTMF relay digit end for 3way conf
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575070: 1076659: Mar 28 2017 19:39:34.511: //458186/21305700000B/CCAPI/cc_api_call_digit_end:
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575071: Consume mask is not set. Relaying Digit 9 to dstCallId 0x6FDC9
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575072: 1076660: Mar 28 2017 19:39:34.511: //458186/21305700000B/CCAPI/cc_relay_digit_end_for_3way_conference:
28-03-2017 19:39:34 Local7.Debug 192.168.35.92 8575073: Check DTMF relay digit end for 3way conf
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575074: 1076661: Mar 28 2017 19:39:34.787: //458186/21305700000B/CCAPI/cc_api_call_digit_end:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575075: Consume mask is not set. Relaying Digit 7 to dstCallId 0x6FDC9
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575076: 1076662: Mar 28 2017 19:39:34.787: //458186/21305700000B/CCAPI/cc_relay_digit_end_for_3way_conference:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575077: Check DTMF relay digit end for 3way conf
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575215: 1076697: Mar 28 2017 19:39:35.067: //458186/21305700000B/CCAPI/cc_api_call_digit_end:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575216: Consume mask is not set. Relaying Digit 2 to dstCallId 0x6FDC9
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575217: 1076698: Mar 28 2017 19:39:35.067: //458186/21305700000B/CCAPI/cc_relay_digit_end_for_3way_conference:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575218: Check DTMF relay digit end for 3way conf
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575351: 1076725: Mar 28 2017 19:39:35.347: //458186/21305700000B/CCAPI/cc_api_call_digit_end:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575352: Consume mask is not set. Relaying Digit 5 to dstCallId 0x6FDC9
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575353: 1076726: Mar 28 2017 19:39:35.347: //458186/21305700000B/CCAPI/cc_relay_digit_end_for_3way_conference:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575354:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575355: Check DTMF relay digit end for 3way conf
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575402: 1076729: Mar 28 2017 19:39:35.619: //458186/21305700000B/CCAPI/cc_api_call_digit_end:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575403: Consume mask is not set. Relaying Digit 0 to dstCallId 0x6FDC9
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575404: 1076730: Mar 28 2017 19:39:35.619: //458186/21305700000B/CCAPI/cc_relay_digit_end_for_3way_conference:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575405: Check DTMF relay digit end for 3way conf
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575406: 1076731: Mar 28 2017 19:39:35.899: //458186/21305700000B/CCAPI/cc_api_call_digit_end:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575407: Consume mask is not set. Relaying Digit 1 to dstCallId 0x6FDC9
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575408: 1076732: Mar 28 2017 19:39:35.899: //458186/21305700000B/CCAPI/cc_relay_digit_end_for_3way_conference:
28-03-2017 19:39:35 Local7.Debug 192.168.35.92 8575409: Check DTMF relay digit end for 3way conf
28-03-2017 19:40:15 Local7.Debug 192.168.35.92 8578328: 1077382: Mar 28 2017 19:40:15.114: //458186/21305700000B/CCAPI/ccGenerateToneInfo:
28-03-2017 19:40:15 Local7.Debug 192.168.35.92 8578329: Stop Tone On Digit=FALSE, Tone=Null,
28-03-2017 19:40:15 Local7.Debug 192.168.35.92 8578330: Tone Direction=Sum Network, Params=0x0, Call Id=458186
28-03-2017 19:40:15 Local7.Debug 192.168.35.92 8578331: 1077383: Mar 28 2017 19:40:15.114: //458185/21305700000B/CCAPI/cc_api_call_disconnected:
28-03-2017 19:40:15 Local7.Debug 192.168.35.92 8578332: Cause Value=16, Interface=0x4147DCE8, Call Id=458185
VG 3945. IOS ver: 15.5(3)M5.
Please suggest if anyone has faced this issue.
thanks & regards,
Ritesh Desai.
03-30-2017 06:37 AM
Hi folks,
Any luck. please help.
regards,
Ritesh Desai.
