Branch Telephones are not registering HO call manager
sujithtalikulam
Hai
I have a issue with my IP phones, I am from Bahrain, I have a CISCO 2921 Voice Gateway, and Fourtinet 100D firewall installed on our Bahrain Branch Office. And all the IP Phones are registered to Head office CUCM (Version 8.6) In head office also we have one Juniper firewall.
Before one week it was working perfectly, but now all the phones are down. now we can't call our head quarter as extensions. But through our Gateway its working. Now all the phone are registered to the gateway.
I checked the status on the phone, but while taking the status the phone is going to Hang.
I try  to get the Xml file from the CUCM but it shows the following error
C:\>tftp -i 192.168.20.11 get SEP34A84E6165A6.cnf.xml
tftp: can't write to local file 'SEP34A84E6165A6.cnf.xml
5 Replies 5
Jaime Valencia
It clearly looks like connectivity issues
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hai
thanks for your response
But how can i identify where is the issue ? which port is blocking or what was the issue ? any idea ?
regards
sujith
Dennis Mink
Mate,
you require some basic troubleshooting,
remeber, things dont just stop working spontaneously. something has changed. stick a laptop in your voice vlan on your remote site or do an extended ping from a voice vlan interface and see if you can ping the call manager.   work your way up the OSI model.
good luck
Please remember to rate useful posts, by clicking on the stars below.
Hai
Problem solved. issue was due to our Routing.
thank you very much.
that was the most likely issue as we indicated.
