CUCM 8.6 install quick question
Hi. We just bought another CUCM cluster and being supplied with 8.6.2.20000_2 installation media, although there is 8.6.2.22900-9 update available on cisco.com.
Question is - is there 8.6.2.22900-9 new installation media or we should install from supplied media and then upgrade to 8.6.2.22900-9?
Could not find fresh install media for 8.6.2.22900-9.
Aman Soi
You need to install with bootable media which has come along with Hardware i.e 8.6.2.20000-2.
After the same is done, you can download the patch 8.6.2.22900-9 and upgrade it.
You won't get downloadable bootable of 8.6.2.22900-9 from Cisco site.
regds,
aman
thanks.
Hi ,
Why do not u upgrade to 8.6(2a)SU3 [8.6.2.23900-10] instead of 8.6(2a)Su2?this got published this month.
Use the link to download 8.6(2a)SU3.
http://software.cisco.com/download/release.html?mdfid=283782839&flowid=26422&softwareid=282074295&release=1.1(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
Please rate the posts.
regds,
aman
Thanks, i know and downloaded it month ago. I just copy&pasted wrong filename for exapmle.
