BRI Isdn Voice Ports locking up
kevinhobson2000
I have an issue where the BRI ports are not always been released after making a call they get permanantley stuck in the state. Details below:
sh voice call summ
PORT CODEC VAD VTSP STATE VPM STATE
0/1/0.1 - - -
0/1/0.2 - - -
0/1/1.1 - - -
0/1/1.2 - - -
0/3/0.1 - - -
0/3/0.2 None - S_SETUP_FAIL S_TSP_WAIT_RELEASE
0/3/1.1 - - -
0/3/1.2 None - S_SETUP_FAIL S_TSP_WAIT_RELEASE
IOS version is 12.4(1)exp.
Config for the BRI is :
nterface BRI0/2/0
description QSIG Trunk in TE mode
no ip address
isdn switch-type basic-qsig
isdn overlap-receiving T302 3000
isdn tei-negotiation remove
isdn point-to-point-setup
isdn incoming-voice voice
isdn global-disconnect
isdn send-alerting
isdn sending-complete
isdn static-tei 0
isdn timeout-signaling
isdn skipsend-idverify
I think this is looking like a software bug but was wondering if anyone has ever seen this.
Any help appreciated.
Cheers
Kev
17 Replies 17
kevinhobson2000
Log output attached.
kevinhobson2000
I see that youre, using 12.4(1) something. Please upgrade to a minimum of 12.4(3j). If you will be using CME and need new features, upgrade to 12.4(11)XJ4.
Thanks for the advice i will upgrade the software and see if it resolves this.
Cheers
Kev
This is experimental software that is based on 12.4.12.
Kev
I have attached some debug output for VTSP, CCAPI inout and isdn events. I am getting this error.
Jun 17 15:57:15.909 BST: ISDN **ERROR**: Module-CCBRI Function-_SetNewChan Error-Cannot get an idle channel from chan mgt. Data-
0, 2
but this could be just because there are no channels available due to the voice ports not being released.
Cheers
Kev
Debug attached.
Which experimental software? Upgrade to 12.4(3j) as suggested above and your issues should be should be solved.
Do you know which bug this relates to?
Kev
There are many. Upgrade to avoid them all.
Ok,
Thanks very much for the advice.
Cheers
Kev
No problem.
Please remember to rate useful posts.
Kev -
I am getting the same error:
ISDN **ERROR**: Module-CCBRI Function-Unknown error function Error-Unknown or unexpected event received. Data- 7, 500
But I am on code: (C2800NM-SPSERVICESK9-M), Version 12.4(19)
__________________
Did upgrading solve your issue? and what code are you running?
Thanks - 3sa
I'm getting the same issue:
This is for a new install. I'm running 124-24.T3 on a Cisco 1861 over BRI using H323
Is this errot message down to a software issue or proble at the Telco end?
