02-11-2017 12:51 PM - edited 03-17-2019 09:29 AM
My company is migrating voice mail from EUM to Office 365. I have to migrate random DN's because we are migrating by departments. So none of the filtering option in BAT add/update line will work for me. I have a CSV file that I can use. I tried to look at uploading file under BAT but there is no option to change the voice profile there. The only line change there is line appearance. I'm not a programmer so I haven't looked into that option. Any ideas?
Solved! Go to Solution.
09-01-2017 03:32 PM
02-12-2017 11:12 AM
Just use Export/Import to export the Directory Numbers, delete the rows you do not want to modify, edit the Voicemail Profile on those that you do, and run an import with the Override the existing configuration checkbox ticked.
02-12-2017 02:36 PM
Jonathan thanks for replying. Unfortunately import/export is limited as to the line options you can update. Although you can make changes to the line appearance you do not have the option to update the voicemail profile field.
02-14-2017 03:25 PM
Bulk Administration > Phones > Export Phones > All Details will give you a CSV file that includes both the Phone and associated Directory Number configurations. This will include the Voice Mail Profile.
02-14-2017 04:04 PM
Thanks I'll try that.
09-01-2017 03:32 PM
05-07-2021 02:19 AM - edited 05-07-2021 05:25 AM
Jonathan, how would you do the import again? Its not possible to to a import via Bulk Administration-->Import-->Import, as you need to have done a Export from here to get the headers that is needed for the import.
What is the recommended way of bulk updating the Voice Mail profiles then really?
PS: the customer is on CUCM v 12.5
BR
Ørnulf
