Bulk change
V.Naveen Kumar
I need change forward all CSS option in line page. its for 150 phones
Is it possible to do in BAT
Yes that's possible.
Please remember to rate all useful posts.
Response Signature
Ayodeji Okanlawon
You can either use Bulk Administration  tab on cucm to do this if the numbers are sequential. If the numbers are not its a little bit difficult. Your options are
1. use the BAT tool add line and select over ride exisitng config when submitting the job. Make sure you fill in all the required details, css, line text label etc
2. You do it manually
3. You use sql to update it directly in the informix databse..if you are familiar with sql and informix.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
