Bulk Disable Enbloc Dialing
Is there a way to disable (in Bulk or Enterprise-Wide) the Enbloc Dialing setting in CUCM 7.x?
When you use BAT, try just selecting phones of a type (e.g. 7962) that you KNOW has the property. I recall if you select 'all' phones it won't display properties not common to all the phone types in the selection.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Vipul Jindal
hello,
what version of 7.x you are running.
i know you can do it from BAT tool in cucm 8 and in some version of 7.
once you tell me the full version i'll be able to confirm you.
thanks,
Vipul Jindal
Exact version is:
7.1(5)bSU4
< or >
7.1.5.33900-10
I don't see it in the BAT but I would love some guidance.
Also, is there a way to set Enbloc Dialing to 'Disable' by default?  It's not an option in the "Common Device Configuration" nor in the Phone Templates.
Thanks in advance for any assistance.
Aaron
That was it - thank you very much!
