Bulk Import File for Hunt Pilot, List, Groups & Members
nt0000001
Hi everybody
I need to créate more than 50 call groups and include users...
How can I create an excel  file and import it ?
I looked in the forums but didn't found how to create this file
thanks for any help
Jaime Valencia
Create a sample config, then use the BAT export feature and you'll get your sample.
java
if this helps, please rate
Thanks for the response but, I'm not used to those sample files ...
what are the basic values that should be presented ?
In which order should complete the file ?
are there some dependency’s ?
Do you have any example ?
