Bulk on 6.1.5 to convert DN from 4 digits lenght to 5 ones failling on some UDP.
rodmont74
Hi, working on a bulk to migrate extension numbers from 4 to 5 digits and most of bulk import in UDP are failling although some of them (11 on 389) passed fine. Still trying to work out any difference but the error we get is:
The bulk file was exported as UDP All details and re-imported as Insert All Details. Does anyone know about this error of empty pattern? Thanks.
_______________________
Insert UDP - All Details
Begin Time : 07/16/2011 15:01:01
Query :
Insert User Device Profiles in  /common/bps/csvfiles/userdeviceprofiles/insert/all/Test-Insert-All-Details-UDP61896-2.csv
Failure Details :
Device Profile Name          Error Code          Error Description
EMP-CLSTGO-HU 61896                    lang.IndexOutOfBoundsException: Index: 1, Size: 1
EMP-CLSTGO-HU 61896          LINE :: Error : 25140          Cannot have an empty pattern when no Partition is specified
Result Summary :
INSERT for 0 USER DEVICE PROFILES passed.
INSERT for 1 USER DEVICE PROFILES failed.
End Time   : 07/16/2011 15:01:04
clileikis
Level 7
Level 7
Hi there,
Could be the following bug:
CSCsx46559 - UDP without line import fails
HTH,
Chris
Thanks for the information. It is the similar situation, and the bug is mentioned for version 7 and 8. It is possible this would happen if an UDP was exported without a DN assigned, which is not the case. When trying a single line DN, will it failing. We fixed manually some 200 DN as migration needed to be concluded by the weekend.
Usually, I'll lab all changes like that but this was a something we worked on fine on other clusters.
