Bulk Update of Softkey Template
cristian.munoz
Level 4
Level 4
Hi Guys
I need perform a bulk update of IP Phone 7921 softkey template only, but I don´t know how to do this.
Any idea?
TIA
Cristian.
jaschulz
Not a great answer for this. There really is no way to edit them in bulk. The only way I've been able to do it and it has a capacity to mess up a lot of users. Is to export and edit the file and re-import.
But to be clear it's only a workaround I've ran into this several times where client was wanting to do mass updates to the users softkeys.
Export/edit/import is a good way to do it if you are handy with CSVs - using Excel tends to scramble the contents so isn't recommended. I wrote some tools to trawl the CSV in a column sensitive fashion to do it neatly.
Another option for you would be to use a little tool I wrote... Take a  look here.
Basically for an input file you would need a line for each device like so
updateDevice,name,SEP123412341234,softkeyTemplateName,TemplateX
updateDevice,name,SEP431243214312,softkeyTemplateName,TemplateY
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Dear Aaron
Thank you for your answer. I´m trying to updating phones using a custom file, but something is missing. The custom file have :
DEVICE NAME,DESCRIPTION,SOFTKEY TEMPLATE
A4934CBFFAA1,,Standard Usuarios
TIA
Cristian
