01-03-2013 12:41 PM - edited 03-16-2019 02:59 PM
Hi Guys
I need perform a bulk update of IP Phone 7921 softkey template only, but I don´t know how to do this.
Any idea?
TIA
Cristian.
01-03-2013 12:58 PM
Not a great answer for this. There really is no way to edit them in bulk. The only way I've been able to do it and it has a capacity to mess up a lot of users. Is to export and edit the file and re-import.
But to be clear it's only a workaround I've ran into this several times where client was wanting to do mass updates to the users softkeys.
01-03-2013 01:52 PM
Export/edit/import is a good way to do it if you are handy with CSVs - using Excel tends to scramble the contents so isn't recommended. I wrote some tools to trawl the CSV in a column sensitive fashion to do it neatly.
Another option for you would be to use a little tool I wrote... Take a look here.
Basically for an input file you would need a line for each device like so
updateDevice,name,SEP123412341234,softkeyTemplateName,TemplateX
updateDevice,name,SEP431243214312,softkeyTemplateName,TemplateY
Principal Engineer at Logicalis UK
Please rate helpful posts...
01-04-2013 08:07 AM
Dear Aaron
Thank you for your answer. I´m trying to updating phones using a custom file, but something is missing. The custom file have :
DEVICE NAME,DESCRIPTION,SOFTKEY TEMPLATE
A4934CBFFAA1,,Standard Usuarios
TIA
Cristian
