10-29-2012 10:35 AM - edited 03-16-2019 01:55 PM
Assuming I'm going to use a Business Edition 6000 with 4 applications on the server, do I need to have 4 network ports?
I'm asking this because reading about the configuration of the Business Edition 6000 UCS C220M3 server, it seems it only has 3 RJ-45 ports, 1 for management and 2 for LAN 1 and LAN 2. Is this correct?
If I configure a UCS C220M3, not for business edition, I would need to add a RJ45 for each application, right?
Thanks.
Solved! Go to Solution.
10-29-2012 11:22 AM
Not really, you configure the vSwitch within ESXi and you can associate zero (in case of internal only vSwitch), one or more physical NICs for the virtual machines to share. You don't need to have a 1:1 mapping between the number of VMs and a physical NIC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-29-2012 11:22 AM
java
11-22-2012 09:29 AM
Thanks a lot Java!!
