03-14-2013 07:01 AM - edited 03-16-2019 04:15 PM
i have on Router 2901 is working as a PSTN Gateway with MGCP to UCM 8.6.2. All it's working fine. But i cannot enter the connand:
mgcp package-capability srtp
dt-ccm-sbhkw-vgw-001(config)#mgcp package-capability ?
as-package Select the Announcement Server Package
atm-package Select the ATM Package
dtmf-package Select the DTMF Package
fm-package Select the FM Package
fxr-package Select the FXR Package
gm-package Select the Generic Media Package
hs-package Select the Handset Package
it-package Select the IT Package
line-package Select the Line Package
mdr-package Select the MDR Package
mf-package Select the MF Package
pre-package Select the PRE Package
res-package Select the RES Package
rtp-package Select the RTP Package
script-package Select the Script Package
sst-package Select the SST Package
trunk-package Select the Trunk Package
The IOS is c2900-universalk9-mz.SPA.151-3.T1.bin. I tried other Version within T-Train. Alos teh UC-Feature are licensed. Why ist the srtp Feature not available?
thx and regards
Ronny
03-14-2013 07:17 AM
Hi Ronny,
I think u should have a security image installed on ISR G2 router since on ISR series u require Advanced IP Services or Advanced Enterprise Services image.
can u try loading a security image with Eval licnese?
regds,
aman
03-14-2013 07:35 AM
Hi Aman,
with Universal Image in Train 15.x we have no distiction between Advanced IP and Base IP etc. The UC Licenses are enabled, security not. How can i enable shis?
regards
Ronny
03-14-2013 07:41 AM
Hi Ronny,
You need to have an image which has UC,Data and Security enabled.Please find the snapshot which I have captured from Cisco Feature NAvigator.
You can get the Evaluation security licnese by cisco.com/go/license by enetring Serial number and UDI of router.Thereafter, u need to buy from Cisco.
You can just the desired command.
regds,
aman
03-14-2013 07:47 AM
Hi Ronny,
In addition to what I have said,you can activate the licenses using this URL?
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html
regds,
aman
