CUCM 6.1 Lock phone 7900 series
Hello Friends,
i want to know if can i close (lock) my phone trhough password. I want to protect my calls.
Thanks friends
Aman Soi
Hi Claudio,
You can use Forced Authorisation Code to protect the outgoing calls from IP phone.
same is configured in Call manager.
regds,
aman
Jaime Valencia
The only options we provide are to use FAC/CMC to associate calls with a user, or use EM to log with your DN.
If you want something that won't allow using the phone unless you type in a pwd, you need a 3rd party.
FYI, this has been asked many, many times before, and a simple search would have provided you the answer. Please search CSC for answers.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
