01-07-2010 10:56 AM - edited 03-15-2019 08:59 PM
Greetings,
Is there anyway to get a C7915 expansion module to work on a C7961 Phone? The C7915 docs do not show the 7961 listed as supported, but just wanted to make sure since CME lets you add the phone 'type 7961 addon 1 7915-24 2 7915-24' and generates a system:/its/vrf1/XMLDefault7961-7915-24-1.cnf.xml files
David
Solved! Go to Solution.
01-07-2010 11:12 AM
CME is wrong, and the sidecar won't work.
01-07-2010 11:12 AM
01-19-2010 10:33 AM
Thanks!
