11-08-2021 11:18 AM
I'm running CUBE on C8000v 17.06.1a and found that it not shows DTMF events with debug voip rtp session named-event 101. The same debug works with older CSR 1000v. Is there a workaround except using monitor capture?
Maxim
11-08-2021 02:42 PM
Certainly debug voip rtp works on the C8000V. When you do "debug voip rtp ?", what are your options?
Maren
11-08-2021 08:40 PM
Thank you for your reply. I can see that DTMF events are generated with debug voip rtp but don't see the details. Here is a debug after pressing 4 and 5:
Nov 9 04:26:25.461: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.461: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.481: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.481: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.501: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.501: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.522: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.522: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.541: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.541: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.561: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.561: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.581: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.581: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.591: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.591: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.591: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.591: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.591: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.591: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.821: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.821: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.841: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.841: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.861: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.861: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.881: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.881: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.901: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.901: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.921: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.921: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.931: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.931: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.931: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.931: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:25.931: //110/2F8D5A000000/VOIPRTP:():voip_rtp_xmit: Nov 9 04:26:25.931: //110/2F8D5A000000/VOIPRTP:():voip_rtp_send_pak: Nov 9 04:26:29.013: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
DTMF method is negotiated, here is SDP fom OK message:
v=0 o=CiscoSystemsSIP-GW-UserAgent 4509 9863 IN IP4 100.123.15.1 s=SIP Call c=IN IP4 100.123.10.18 t=0 0 m=audio 8208 RTP/AVP 8 101 c=IN IP4 100.123.10.18 a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=ptime:20
I see correct debug if I route a call to CSR 1000v with the same config so it is a bug or debug syntax has changed.
11-09-2021 06:13 AM
That's why I was asking what you see in your C8000V if you type in "debug voip rtp ?" What are the additional syntax options? If "debug voip rtp session named-event 101" is there as an available command, I would guess you are running into a bug. If it is not there as an available command, what are the other commands that are available? We may be able to find a different command that gives you the information you need.
Maren
11-09-2021 10:12 AM
I misunderstood you, debug command is correct but not working.
COBALT-RTR#debug voip rtp ? all Enable All VOIP RTP debugging default Activates inout, error, and function debugs error Enable VOIP RTP Error debugging trace function Procedure tracing high-availability VOIPRTP high-availability debugs individual Activation of individual VOIP RTP debugs inout Subsystem inout debugging packet Enable VOIP RTP Packet debugging trace recvfail simulating rtp recv failure sendfail simulating rtp send failure session Enable VOIP RTP Session debugging trace statistics Enable VOIP RTP Statistics debugging trace <cr> <cr> COBALT-RTR#debug voip rtp session named-event ? <98-117> payload value <cr> <cr>
11-10-2021 07:13 AM
Hmmm... I don't know the answer. As you suggested, if the command is there but showing no useful output you are probably running into a bug...which makes your next step contacting TAC. I wish I could have been more help.
Maren
