04-25-2023 04:13 AM
Can anyone help me with the SIP/CUBE calls limitation document for the C8300-1N1S-6T.
Solved! Go to Solution.
04-25-2023 07:26 AM - edited 04-25-2023 09:54 AM
I think this should be what you're looking for. Cisco Unified Border Element Version 14 Data Sheet At least if you’re looking for max number of simultaneous calls and call setup per second.
