call between two cucm
kingstdz
we have two cucm on each site, with gateway ,linked by wan
my gw is on h323, we have declared sip trunk between site, and RP but give us 503 error ,, 5060 port is not blocked,
how to fix that and if there is other solution to permit call between via GW voice of each side.
thanks
32 Replies 32
otherwise is there other solution via GW of my site and GW of other site, any steps to do it i will apreciate it thanks a lot
Sorry to say this, but as you can’t get the basic setup with SIP trunks between two CMs to work it’s not worth trying to get a connection via a gateway, or multiple, that acts like an SBC to work as it’s a much more complex situation.
Response Signature
Again if you share the requested information we can help you. Without it I’m afraid that we will not get anywhere with this. So far what you share doesn’t help narrowing down the issue and you’re not very clear in what you write. All this is at the moment working against you. Sorry to say that, but we cannot help you if you persist to withhold the information requested.
Response Signature
