Call delay on incoming CUCM 9.1.1
zdesignstudio
Level 4
Level 4
I am experiencing an issue with users experiencing a delay in the RTP stream on incoming calls. This is happening at a particular location and occurs with incoming site calls as well as incoming via the ITSP. This is a clustered infrastructure with Cisco UBEs. Site A answers ringing phone and says "Thanks for calling, this is Bob how can I help you?" and people on the other end are only hearing "I help you?" etc.
Site 1 ----- CUBE_A ----- ITSP
Site 2 ----- CUBE_A
Site 3 ----- CUBE_A
ETC ETC
It is not happening at all sites that share the CUBE's trunk to the ITSP so I dont think its an issue with the SIP profile or trunk. Also, since this happens between sites, I dont believe the trunk is the issue.
QOS is configured the same on all sites. This includes ones that have no issues.
I checked WAN links and everything seems good.
I checked the switch and everything seems good on ports as well as the trunk to the router.
We are running 6921 and 7942 phones.
Stumped.
Any ideas would be greatly appreciated.
Please rate useful posts and mark answers as correct if applicable.
dsutphin
CSCue50773
upgrade
Dennis Sutphin Jr.
15 Replies 15
Hi.
Please attach a debug ccsip messages during a delayed call.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Carlo,
Please see below. Thanks
540622: Nov  8 18:49:50.783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:xxxxxxxxxx@xxx.xx.xx.xx SIP/2.0
Via: SIP/2.0/UDP 72.11.192.82:5060;branch=z9hG4bKq348mg304gnh1lgq90k0.1
From: <>xxxxxxxxxx@xx.xx.xxx.xx;user=phone>;tag=650915513-1383936590732-
To: "xxxxxxxxxx xxxxxxxxxx"<>xxxxxxxxxx@xxx.xx.xx.xx>
Call-ID: BW1349507320811131982825720@xxx.xx.xx.xx
CSeq: 478560711 INVITE
Contact:
Supported: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY
Accept: application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 39
Content-Type: application/sdp
Content-Length: 197
Route:
v=0
o=- 2178467081 1 IN IP4 72.11.192.93
s=-
c=IN IP4 72.11.192.93
t=0 0
m=audio 49376 RTP/AVP 18 0 8 101
a=ptime:20
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
540623: Nov  8 18:49:50.785: //3157575/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP xx.xx.xxx.xx:5060;branch=z9hG4bKq348mg304gnh1lgq90k0.1
Date: Fri, 08 Nov 2013 18:49:50 GMT
Call-ID: BW1349507320811131982825720@72.11.192.10
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M2
Content-Length: 0
540624: Nov  8 18:49:50.785: //3157576/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:xxxxxxxxxx@xx.xx.25.100:5060 SIP/2.0
Via: SIP/2.0/UDP xxx.xx.54.50:5060;branch=z9hG4bK192FCD273
To:
Call-ID: 61F241CE-47DD11E3-9094C585-F9DDAC26@172.16.54.50
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1643246522-1205670371-2425275781-4192054310
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1383936590
Contact: <8138188597>
Expires: 180
Max-Forwards: 38
Content-Disposition: session;handling=required
Content-Length: 306
v=0
o=CiscoSystemsSIP-GW-UserAgent 1124 8737 IN IP4 xxx.xx.54.50
s=SIP Call
c=IN IP4 172.16.54.50
t=0 0
m=audio 27782 RTP/AVP 18 0 101 19
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
540625: Nov  8 18:49:51.151: //3157576/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To:
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
540630: Nov  8 18:49:51.578: //3157576/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: ;tag=991105~c5c64f56-4dee-4ada-bc88-2c1fc1fa65c2-106983788
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: <8009950>
Remote-Party-ID: <8009950>;party=called;screen=yes;privacy=off
Contact:
Content-Length: 0
540631: Nov  8 18:49:51.578: //3157575/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP xx.xx.192.82:5060;branch=z9hG4bKq348mg304gnh1lgq90k0.1
To: "xxxxxxxxxx xxxxxxxxxx"<>xxxxxxxxxx@xxx.xx.54.50>;tag=C7F22CCC-175B
Call-ID: BW1349507320811131982825720@xx.xx.192.10
Require: 100rel
RSeq: 7856
Contact: <>xxxxxxxxxx@xxx.xx.54.50:5060>
Content-Length: 0
540632: Nov  8 18:49:51.680: //3157576/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.16.54.50:5060;branch=z9hG4bK192FCD273
To: <>xxxxxxxxxx@xx.xx.xx.100>;tag=991105~c5c64f56-4dee-4ada-bc88-2c1fc1fa65c2-106983788
CSeq: 101 INVITE
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
P-Asserted-Identity: "VoiceMail" <>8009950@xx.xx.xx.100>
Remote-Party-ID: "VoiceMail" <>8009950@xx.xx.xx.100>;party=called;screen=yes;privacy=off
Contact: <>xxxxxxxxxx@xx.xx.xx.100:5060>;isFocus
Content-Length: 237
v=0
o=CiscoSystemsCCM-SIP 991105 1 IN IP4 xx.xx.xx.100
s=SIP Call
c=IN IP4 xx.xx.xx.220
b=TIAS:64000
b=AS:64
t=0 0
m=audio 23398 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
540633: Nov  8 18:49:51.680: //3157576/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:xxxxxxxxxx@xx.xx.xx.100:5060 SIP/2.0
Via: SIP/2.0/UDP xxx.xx.54.50:5060;branch=z9hG4bK192FCF19CE
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
540634: Nov  8 18:49:51.730: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:xxxxxxxxxx@xxx.xx.54.50:5060 SIP/2.0
Via: SIP/2.0/UDP xx.xx.xxx.xx:5060;branch=z9hG4bK9sd1cr2048h0sk04t0n1.1
From: <>xxxxxxxxxx@xx.xx.xxx.82;user=phone>;tag=650915513-1383936590732-
CSeq: 478560712 PRACK
RAck: 7856 478560711 INVITE
Max-Forwards: 39
Content-Length: 0
540635: Nov  8 18:49:51.730: //3157575/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP xx.xx.192.82:5060;branch=z9hG4bK9sd1cr2048h0sk04t0n1.1
From: <>xxxxxxxxxx@xx.xx.192.82;user=phone>;tag=650915513-1383936590732-
Date: Fri, 08 Nov 2013 18:49:51 GMT
Content-Length: 0
540636: Nov  8 18:49:51.730: //3157575/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 3678 1750 IN IP4 xxx.xx.54.50
s=SIP Call
c=IN IP4 xxx.xx.54.50
t=0 0
m=audio 21634 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
540637: Nov  8 18:49:51.830: //3157575/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "xxxxxxxxxx xxxxxxxxxx";tag=C7F22CCC-175B
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 3678 1750 IN IP4 172.16.54.50
s=SIP Call
c=IN IP4 xx.xx.54.50
t=0 0
a=fmtp:101 0-15
a=ptime:20
540638: Nov  8 18:49:51.890: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP xx.xx.192.82:5060;branch=z9hG4bKgcsr47206gd1capu06g1.1
CSeq: 478560711 ACK
Contact:
Max-Forwards: 39
Content-Length: 0
540639: Nov  8 18:49:51.898: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 478560711 ACK
Contact:
Max-Forwards: 39
Content-Length: 0
540703: Nov  8 18:50:08.461: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:xxxxxxxxxx@xxx.xx.54.50:5060 SIP/2.0
Via: SIP/2.0/UDP xx.xx.25.100:5060;branch=z9hG4bK13b33c51f9fd25
From: <>xxxxxxxxxx@xx.xx.25.100>;tag=991105~c5c64f56-4dee-4ada-bc88-2c1fc1fa65c2-106983788
To: <>xxxxxxxxxx@xxx.xx.54.50>;tag=C7F229B4-2319
User-Agent: Cisco-CUCM9.1
Max-Forwards: 70
Supported: timer,resource-priority,replaces
CSeq: 101 UPDATE
P-Asserted-Identity: "Billy Bob" <>3389110@xx.xx.25.100>
Remote-Party-ID: "Billy Bob" <>3389110@xx.xx.25.100>;party=calling;screen=yes;privacy=off
Contact: <>xxxxxxxxxx@xx.xx.25.100:5060>
Content-Length: 0
540704: Nov  8 18:50:08.461: //3157576/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.10.25.100:5060;branch=z9hG4bK13b33c51f9fd25
Date: Fri, 08 Nov 2013 18:50:08 GMT
CSeq: 101 UPDATE
Supported: timer
Content-Length: 0
540748: Nov  8 18:50:16.265: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:xxxxxxxxxx@xxx.xx.54.50:5060 SIP/2.0
Via: SIP/2.0/UDP xx.xx.25.100:5060;branch=z9hG4bK13b3473348aa88
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
540749: Nov  8 18:50:16.265: //3157575/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:xx.xx.192.82:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP xxx.xx.54.50:5060;branch=z9hG4bK192FE01378
From: "xxxxxxxxxx xxxxxxxxxx"<>xxxxxxxxxx@xxx.xx.54.50>;tag=C7F22CCC-175B
To: <>xxxxxxxxxx@xx.xx.192.82;user=phone>;tag=650915513-1383936590732-
Max-Forwards: 70
Timestamp: 1383936616
CSeq: 101 BYE
P-RTP-Stat: PS=1065,OS=170400,PR=1220,OR=194108,PL=0,JI=0,LA=0,DU=24
Content-Length: 0
540750: Nov  8 18:50:16.265: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 08 Nov 2013 18:50:16 GMT
Call-ID: 61F241CE-47DD11E3-9094C585-F9DDAC26@xxx.xx.54.50
CSeq: 102 BYE
P-RTP-Stat: PS=1220,OS=194108,PR=1065,OR=170400,PL=0,JI=0,LA=0,DU=24
Content-Length: 0
540751: Nov  8 18:50:16.337: //3157575/61F1F3BA908E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.16.54.50:5060;branch=z9hG4bK192FE01378
CSeq: 101 BYE
Content-Length: 0
So I am also facing same issue .We only see the issue when you call to specific location so I believe its more about that GW rather than the CuCM.
CuCM version: 9.1.2
 GW Version 15.1
Any thought?
Jagpreet Singh
When you say that site to site calls also face the same issue, what is the exact call flow in that case?
Example : ip phone 1 (site A) >> cucm >> ip phone 2 (site b)
Or
Ip phone 1 >> cucm >> sip >> cube >> sip >> cucm >> ip phone 2
Jagpreet
Sent from Cisco Technical Support Android App
The call flow is as follows:
Site 1 -- Site Gateway -- MPLS Cloud -- CUBE 2 -- CUCM -- CUBE 1 or 2 -- MPLS Cloud -- Site Gateway -- Site 2
That is for signaling. The RTP stream for site to site calls goes as follows:
Site 1 -- Site 1 Gateway -- MPLS Cloud -- Site 2 Gateway -- Site 2 Phone
The flow for PSTN calls is as follows:
Site 1 -- Site 1 Gateway -- MPLS Cloud -- CUBE 1 -- ITSM
I forgot to mention that these calls flow through the IVR with Unity Connection. The issue only seems to happen when calls are routed through UC.
zdesignstudio
Level 4
Level 4
Any ideas?
rliu
Hi. Did you get a resolution to this as the symptoms match an issue a customer is having?
Richard,
The issue has been resolved. We were expierencing a Cisco bug related to queuing and upgrading to 9.1.2 or 9.2.1 solved it. I forgot the version we went to but it was speifically made to address this bug.
Thanks and good luck.
whats the bug id
CSCue50773
dsutphin
CSCue50773
upgrade
Dennis Sutphin Jr.
issue has started re-occuring currently running CUCM 9.1.2 we have also upgrade Unity connection to the same version as well as use new OVA template and recreated all of our VM with 4 cpu. AS they origianlly only had two cpu cisco thought that could have been causing issue. Our issue seems to start off with a single site and continue to grow now to multiple sites reporting the same 3 to 5 sec delay issue. I am running out of ideas? Any one else got one.
Dennis Sutphin Jr.
Driss Hadi
Hello Collaboration team
Please i have the same issue ,  i upgraded my box from CUCM 7.1 to 9.1 at the remote location the users start to complain about delay to resppond to the call about 3 sec ( the can her only how we can help ) ? can use the same procedure or my case difirent
