Call disconnecting in CME after pickup
ctsvoiceteam
hello champs,
 Call got disconnecting immediately after answering the call in CME, this is happend only when call is came through SIP trunk, below is the set up
CUCM -> SIP Trunk->CME
when we make a call from CUCM  to CME this is happend, but when we make the call from CME to CUCM its fine. here i attached the debug ccsip messege,
please help guys.
16 Replies 16
Glad to know its working now..
Here is the clue to knowing where the issue was..
The original logs showed this..
++ 200 OK sent to CUCM from CCME contains no DTMF method ++
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 172.25.225.11:5060;branch=z9hG4bK6884133e9bb02
From: <sip:52333@172.25.225.11>;tag=4279344~b8eb621a-bc9d-4a8c-9274-855b9682f601-75071428
To: <sip:60090@192.168.60.65>;tag=AE756D24-2693
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 433
v=0
o=CiscoSystemsSIP-GW-UserAgent 6922 6961 IN IP4 192.168.60.65
s=SIP Call
c=IN IP4 192.168.60.65
t=0 0
m=audio 19700 RTP/AVP 18 0 8 9 4 96 15 19
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=fmtp:9 bitrate=64
a=rtpmap:4 G723/8000
a=fmtp:4 bitrate=6.3;annexa=no
a=rtpmap:96 G726-32/8000
a=rtpmap:15 G728/8000
a=rtpmap:19 CN/8000
+++ the ACK received from CUCM contains RFC2833/rtp-nte +++
Oct 17 05:20:41.246: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:60090@192.168.60.65:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.25.225.11:5060;branch=z9hG4bK688433f690985
Content-Length: 249
v=0
o=CiscoSystemsCCM-SIP 4279344 1 IN IP4 172.25.225.11
s=SIP Call
c=IN IP4 172.25.170.25
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 28200 RTP/AVP 9 101
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=fmtp:101 0-15
+++ DSP Alarm ++
Immediately after the ACK sent by CUCM, you then get the following IEC error ++
Oct 17 05:20:41: %DSMP-3-DSPALARM: Alarm on DSP : status=0x0 message=0x0 text=N
Oct 17 05:20:41: %VOICE_IEC-3-GW: VTSP: Internal Error (DSP alarm): IEC=1.1.182.9.27.10 on callID 120254 GUID=DD6C53000001000000012B140BE119AC
++ Conclusion ++
Hence from both of these logs, I was able to deduce that CCME is trying to invoke some media resources and it can only be due to DTMF mismatch
Please rate all useful posts
got it, thanks a lot ayodeji...
