Call Drop on Consult Transfer
mmaamm238
I have a problem with consult call transfer. I have SIP trunk with ITSP. When I want to transfer an external call from 7965 to 7945 it drops but from 7945 to 7965 is successful. Both phones can call to each other and outside and blind transfer works without problem. My CUCM version is 11.5.
How can I troubleshoot it? Is it signaling or codec problem?
39 Replies 39
Dear Carlo,
Only Cisco CallManager service logs?
Hi.
They could be enough but if you can, please select all services
Thanks a lot
Carlo
Please rate all helpful posts "The more you help the more you learn"
Dear Carlo,
Is it enough?
As I suspected , there is a real capabiliies mismatch during the transfer:
PreCheckCapabilities, caps mismatch! Xcoder Reqd
and the call ended with no transcoder device configured message
To dig more, you could temporarly set to "detailed" level the CM Service trace goin on Cisco Unified Serviceability Menu -->Trace--> Configuration.
In the Output you sent I cannot see the incoming call.
Please send the complete SDL trace so we can find where to place the fix
Thanks again.
Carlo
Dear Carlo,
Here it is:
On CUCM go to "System--> Enterprise Parameters" and set to "Disabled"  the Advertise G.722 Codec option , reset both phones and try again.
If ther transfer  fails again please attach a new SDL trace log.
Please let me know
Carlo
Dear Carlo,
Thank you very very very much.
May I ask you to explain the problem and solution?
You are most welcome!
While 7945 negotiated G711ulaw codec on the second call to 7965 before transfer, 7965 to 7945 negotiated G722 on second call and this caused the call drop due to a missing Transcoding resource needed  to mix those 2 RTP flows. A Blind Transfer "forces" to use original negotiated Codec in original call. By  Disabling the advertisement of G722 codec, all registered deviced on your Cucm Cluster will no longer advertise G722 as usable codec.
Carlo
In which line of logs you found this?
In the log we can find 2 CI (Call Identifier) that are the 2 call legs of the call: 31706028 which is the CI between CUCM and CUBE (SIP Trunk) and CI  31706034 between CUCM and SCCP Phone with Device Name SEPE84040A38306 which executes the call transfer.
Here you can see that the Call ID becomes a Conference ID because the user with 706 initiate a consult transfer to 710
PayloadType=6 CI=31706034 DiffServ=0xb8 (DSCP=0x2e) Silent=0 MaxFrms=0 G723BitRate=0 PartyId=0x1007569 RFC2833PayloadType=0 mixingMode=0 partyDir=0
09956474.001 |14:57:26.350 |AppInfo |StationD: (0000456) startMediaTransmission conferenceID=31706034 passThruPartyID=16807273 remoteIpAddress=IpAddr.type:0 ipAddr:0xc0a86120000000000000000000000000(<<<IP15>>>) remotePortNumber=31178 milliSecondPacketSize=20 compressType=6(Media_Payload_G722_64k) RFC2833PayloadType=0 qualifierOut=?. myIP: IpAddr.type:0 ipv4Addr:0xc0a8610d(<<<IP7>>>)
Here we can see  that  the CUCM searches for a transcoding resources but it cannot allocate one.
956995.029 |14:57:31.756 |AppInfo |DET-MediaManager-(12105)::sendMTPXcoderAllocationRequest, (CapCount,Region),SideA:(6,Default), SideB:(1,Default), supressMatchCap=0,MTPNeededForDTMF=0
09956995.030 |14:57:31.756 |AppInfo |SIG-MediaManager-(12105)::sendMTPXcoderAllocationRequest, allocate xcoder(ci=31706040), suppressMatchCap=0, mrgl=18dcfe5d-aab2-9e9e-f97b-5d919584ec56 DeviceCapsReqdMask=0x0
09956995.031 |14:57:31.756 |AppInfo |DET-MediaManager-(12105)::allocateProxies, j=2 XferMode(4 0) CI(31706034 0) mrid(0 0) resrcCI(0 31706040)
09956995.032 |14:57:31.756 |AppInfo |SIG-MediaManager-(12105)::allocateProxies, allocating resources(1), additional res(0)
09956996.000 |14:57:31.756 |SdlSig |MrmAllocateXcoderResourceReq |waiting |MediaResourceManager(1,100,140,1) |MediaManager(1,100,142,12105) |1,100,14,1.44026^*^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=31706040 MRGLPkid=18dcfe5d-aab2-9e9e-f97b-5d919584ec56 Kpbs=0 RegionA=Default CapA=6 RegionB=Default CapB=1 SuppressFlag=0 Type=1 DeviceCapablity= [0x0]0 MandatoryCapabilties= [0x0]0 Count=1
09956996.001 |14:57:31.756 |AppInfo |MediaResourceManager::waiting_MrmAllocateXcoderResourceReq - CI=31706040, Count=1
09956996.002 |14:57:31.756 |AppInfo |MediaResourceManager::waiting_MrmAllocateXcoderResourceReq - CREATING CHILD USING MRGL LIST
09956996.003 |14:57:31.756 |AppInfo |MRM::convertScmStringToStdString MRG
09956996.004 |14:57:31.756 |AppInfo |MRM::getXcodeDeviceGivenMrgl
09956996.005 |14:57:31.756 |AppInfo |MRM::getXcodeDeviceGivenMrgl GETTING XCODE FROM DEFAULT LIST  <<--Searching for Transcoding resource
09956996.006 |14:57:31.756 |AppInfo |MediaResourceManager::sendAllocationResourceErr - ERROR - no transcoder device configured
09956996.007 |14:57:31.756 |AppInfo |GenAlarm: AlarmName = MediaResourceListExhausted, subFac = CALLMANAGERKeyParam = , severity = 4, AlarmMsg = MediaResourceListName : MRGL
MediaResourceType : 2
MediaResourceTypeValue : Transcoder
AppID : Cisco CallManager
ClusterID : StandAloneCluster
NodeID : CUCM
And here sends the call disconnect.
09956996.008 |14:57:31.756 |AppInfo |GenAlarm: Push_back offset 680 seq 4684
09956996.009 |14:57:31.756 |AppInfo |GenAlarm: Pop offset 681 seq 3684
09956997.000 |14:57:31.756 |SdlSig |MrmAllocateMtpResourceErr |waitResourcesAllocated |MediaManager(1,100,142,12105) |MediaResourceManager(1,100,140,1) |1,100,14,1.44026^*^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=31706040 MRGLPkid=
09956997.001 |14:57:31.756 |AppInfo |DET-MediaManager-(12105)::waitResourcesAllocated_AllocateMtpResourceErr, resCI=31706040, numRes=1, numPreRes=0
09956997.002 |14:57:31.756 |AppInfo |DET-MediaManager-(12105)::waitResourcesAllocated_AllocateMtpResourceErr, numRsrcRes=1, sizeRsrcList=1, failCall=1 resAllocationFailReason=Xcoder ipv6mtp=0
09956997.003 |14:57:31.756 |AppInfo |DET-MediaManager-(12105)::cleanUp, send MediaUpdateDisconnectStatus, reConnectType=0, sendErrIndToParent=0, failCall=1
Please let me know if you need further info.
Carlo
