Call Duration
Syed
Level 3
Level 3
Dear All,
Is It possible to fetch total call duration exclusively of all mobile, national & international calls on monthly basis from CUCM?
Thanks in advance
Syed
2 Accepted Solutions
Jitender Bhandari
Hi Syed,
there is not such Custom CDR report that would give that information.
You can take CDR dump and then if you know how to play around with Microsoft Excel you can do lot of powerful things with that.
JB
Hi Syed,
You can run such reports using 3rd Party CDR Accounting Application such as like this:
http://www.commsouth.com/commcontrol-call-accounting-software.php
You will also have many more such custom reports supported by the application.
Prasana Kumar.P
(prasana@commsouth.com)
Please rate if useful.
Regards, Prasana Kumar.P +919841027006
5 Replies 5
Jitender Bhandari
Hi Syed,
JB
Thank you JB for your quick answer.
I wanted to double check on that, thanks again
Happy to help,
Also the options provided by Prasana can be useful.
JB
Hi Syed,
Prasana Kumar.P
Thanks Prasana.
I shall look into that.
