Call failing with a DSP error
jeesemon.91
Hi Guys,
when we make an outbound call it fails and showing below error in gateway
 %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally
i haven't configured any dsp farm profile, i could see 64 channel are free. but still i got this error. i have done the dsp reset as well.
IOS version :c2900-universalk9-mz.SPA.154-3.M3.bin
router model: CISCO2901
Utilization: 0.00 percent
Total channels: 64
Inuse channels: 0
Disabled channels: 0
Pending channels: 0
Free channels: 64
6 Replies 6
Jaime Valencia
You need to provide a sh run to see what you have configured and what might be the error.
java
if this helps, please rate
please find attached the show run
Add an output for "show voice dsp group all" and "show voice dsp error".
DSP groups on slot 0:
dsp 7:
State: FAIL, firmware: 37.3.6
Max signal/voice channel: 32/32
Max credits: 480, Voice credits: 480, Video credits: 0
num_of_sig_chnls_allocated: 32
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 480, reserved credits: 0
Signaling channels allocated: 32
Voice channels allocated: 0
Credits used (rounded-up): 0
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
dsp 8:
num_of_sig_chnls_allocated: 28
Signaling channels allocated: 28
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
19 DSP resource allocation failure
No DSP errors logged
Your DSP cores are in a failed state. Reboot the router and see if the state changes to an UP. If not, you would need to replace the PVDM's.
Joshua Falso
I ran across this thread because one of the sites I support had this same issue. I was getting DSP Timeout errors and we reloaded the router and the DSP's came up in a FAIL STATE.
I then powered off the router (2951) completely and unplugged the cable. Waited a few minutes and powered back on and everything worked. I believe the PVDM's are going bad and I need to replace them but this bought me some time.
V/r Josh
