Call flow
jazabhish
Hi all, can someone tell me how the call flow from PSTN to Cisco IP Phome (No IPCC) ?
Atul Khanna
This is something you should ask your local network administrator.
-Atul
Hi Atul, m just asking the concept .
This is a very generic scenario, it totally depends on the network topology.
-Atul
Most basic scenario is:
PSTN - GW - CUCM - IP Phone.
You would need to look at your whole CUCM/GW config to find out exactly what you're doing with the calls.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
