Call Forward All OFF is not working on 8851
wilsonsant
Level 6
Level 6
Hi Guys,
I am trying to use the bottom Call Forward all in IP Phone 8851, but, when I dial the first digit hear the message: "not is possible to complete the call please to consult ....". I verified the configuration about IP phone, but, didn´t found error.
Any have idea about this?
Wilson
2 Accepted Solutions
"You call cannot be completed as dialed..." is most definitely a CSS issue.
What is the CFA CSS Activation Policy set to? if default, what do you have that configured to?
java
if this helps, please rate
Please, attach (as file) the SDL logs from CUCM, along with the calling, called and forwarded numbers.
Georgios
Please rate if you find this helpful.
5 Replies 5
Georgios Fotiadis
Check that the call forwarding CSS at line configuration section matches that of device configuration.
Georgios
Hi Georgios,
Thanks a lot for Your contact. This information was verified and is correct.
Wilson
java
Hi Jaime Valencia,
Were configured with the option "With Configured CSS" and changed to "With Activating Device/Line CSS". After this change worked fine.
Wilson
Georgios
