Call Forward Missed Call Notification? [Solved]
user101111
I have a user who is requesting the below functionality:
Phone A (Internal VoIP or External)
Phone B (Internal VoIP)
Phone C (External)
Phone B and C have different phone numbers. We're running CUCM version 10.5
Phone B is configured to forward all calls to Phone C. When Phone A calls Phone B, the call is forwarded to Phone C. If Phone C does not answer they want to see a missed call notification on Phone B (which includes Phone A's phone number). I'm not sure if this is possible but wanted to ask before I tell them it can't be done.
* Update*
I found a workaround: Set Phone B to only forward calls on no-answer and set the no-answer for that DN to 1 ring.
Jaime Valencia
That's not possible, for a phone to have a missed call, it has to ring, and with CFA that does not happen.
java
if this helps, please rate
Ratheesh Kumar
Hi there
Please see if Missed call Notifications device section can play you the trick
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/12x/administration/guide/b_12xcucsag/b_12xcucsag_chapter_01101.html#ID-2415-00000039
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Thank you for the reply. The issue is less to do with voicemail. I edited my original post to reflect notifications for only missed calls.
Jaime Valencia
java
That works for me. Thank you!
