CUCM Disk partition
Vijay Patil
Level 3
Level 3
Can any one help me with the difference between Log partition vs Active partition vs Common partition
is there anything is missing out in this for disk usage please share your inputs
Rajan
Hi Vijay,
show status command will list you all the partitions and its usage.
These are the three partitions created in an UC application like CUCM during installation.
Disk/active - holds the current version and its configuration
Disk/inactive - contains the previous version in case you need to swithc after an upgrade for any reason
Disk/logging - this is also called common partition which holds all the enabled log/trace files and also used to store the upgrade iso file during upgrade temporarily
Rajan
Pls rate all helpful posts
good answer¡¡
Luis Coiro
