Call Forward to Multiple External Numbers
jefferymitchell
Is it possible to CFA to multiple numbers?
2 Accepted Solutions
Hi Jeff,
I would suggest using SNR you can ring multiple Remote destination with that.
(Rate if it helps)
JB
Single Number Reach is the way to go.
Hunt Groups will ignore the Call Forward All option on member phones so this will not be an option.
8 Replies 8
Jitender Bhandari
Hi Jeff,
With the current architecture you cannot, what you can do it is to forward it to an hunt pilot and use broadcast to ring multiple phones simultaneously if that's what you are looking for.
(Rate if it helps)
JB
Thanks Jitender,  I want to forward the calls to 3 different external numbers and have them all ring at the same time. If I set up a hunt group can I forward to the external from the DN'S that are part of the hunt group?
Hi Jeff,
(Rate if it helps)
JB
Thanks Jitender yes SNR sounds like the solution. I appreciate your support.
Hi Jeff,
Happy to help.
JB
I test this with SNR but its ringing only one pstn mobile number is there any way do this with circular option ?
SNR is not ringing two mobile phone I want to ring that pstn phone one by one with circulary algorithm.
Thanks I appreciate the support. SNR sounds like the solution.
