Call forward to two different numbers
Ishaan Johari
  Hi All
Is it  posible that, when anyone call from outside a particular number (E164),
during off hours call is been  forwarded to two different mobile numbers at the same time.
i dont know much about this
Aaron Harrison
A forward would go to one number only.
The only way I can think of that you could get it to forward to more than one would be: if you are on CUCM 6+ you could set up a number with the 'Mobility' (Single Number Reach) feature with two mobile numbers as remote destinations. You would then forward to this number which would fork the call out to two endpoints.
There will be lots of examples of this configuration on these forums and elsewhere.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks  a Aron,
But for that i have to make 2 remote destination profile and
than can i associate those two with one number
please tell wheather i got it right or not
You would have one extension, e.g. 1234.
This would have a single 'Remote destination profile'.
There would then be two 'Remote Destinations' added to referring to that profile.
An example here: http://alexsj9.blogspot.co.uk/2010/01/single-number-reach-aka-snr-in-5.html
I would get one external phone working, then add the second.
Aaron
