Call forwarding from PSTN line to PBX
Udupikrishna091
I have a setup in my voice gateway where there is FXO card with 4 ports and there is a PSTN line connected to one of the ports. As of now i am making outgoing calls from my IP phone which goes through this pstn line. I have another line which is a Centrex connection [PBX] connected to another port, My requirement is if my basic pstn line is busy, my call should go through the other line, is this possible if the other line is a PBX line where i have to use '0' as the beginning number to get the line active.
Krishna
Jonathan Schulenberg
Sure. Just have a second dial peer with a higher preference value on it and the same destination-pattern value. You can use prefix 0 to get the trunk access code added.
Hi Jonathan,
                         Thanks for the reply. the doubt i am getting is pretty lame, now for example if i connect the PBX line to a analog phone, i need to dial '0' then I will be getting the dial tone then i can dial a number!!!!, now if i have a prefix set in call manager, which would be discarded later. if 0 is my prefix and which would be discarded and I need one more zero to make the PBX line active, i cant send a single zero to the PBX through Call manager, if I dail 00XXXXXX, my first 0 will be discarded but when this goes to PBX it is dropped because it takes only zero, this is where exactly I am facing the issue. Is there any way that can make this work.
Krishna
Are you controlling the analog port through MGCP; or, using H323/SIP dial-peers between CUCM and the router?
If you're using MGCP: You can add the extra zero character by placing the two ports in separate route groups. The route list will allow you to do per-route group transformations. For the normal PSTN route group you add nothing. For the Centrex route group you prefix another zero.
If you're using H323/SIP: Just use 'prefix 0' on the outbound POTS dial-peer that is bound to the Centrex port.
If you are using MGCP and you add the new route group to your route list, all you need to match is your original route pattern (don't pre-pend anything).  From the orignal post, it sounds like you are not sending the leading 0 to your PBX, so it is not stripping it, and it is actually dialing 0 (when the call is delivered).  If you have it properly configured on your RP-RL-RG, you shouldn't have to pre-pend anything.
