call forwarding in CUCM
yeow28
Can i set a duration for the call forwarding from a phone number within my CUCM to a external number ?
eg forward my own extension number to my mobile during office hours (9.00am to 5.00pm) ?
can this be done in the CUCM ?
right now after i set the forwarding, it will forward all calls to my mobile at any time when some one call my DID
gearbox
You can do this with mobility (Single Number Reach) and you can set the schedule within the remote destination profile.
Gear Misner
HyeTech Network & Security, LLC
@collabcowboy
George Sotiropoulos
Dear day28lite,
This can be implemented on CUCM via "time of day routing" configuration. Below you can find the configuration example:
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/109588-tod-routing-example00.html
I hope this helps,
George
Hope the above helps,
gsotirop
