IP Telephony and Phones
Labels
Hi people, Usually when i did configure a cisco phone i tape the info on the call manager (maccaddres, extension number, extension name, etc.) and when i put the phone on lan he went to looking for the call manager, the call manager sent to the phone...
We have 100+ 7925G wireless phones that we configured the EPNM on the primary line for each phone.  Where the Phone DN used to be displayed in the upper right corner of the phone screen is now the EPNM.  Is there a way to change it back Wireless Phon...
mrstewart by Level 1
  • 335 Views
  • 0 replies
Hello, We have been having some issues with voice recording, only one side of the conversation is being recorded, Cisco side. Examples of two different calls:  Cisco phone (local Cluster CUCM 11.5) to an external number (PSTN) over a Voice Gateway on...
I'm unpicking some of the dustier corners of our CUCM setup and hit something I can't work out. We've got some MGCP Euro ISDN-30 trunks. With Euro ISDN, the leading zero of the presentation number is not sent by the network. Yet when the presentation...
I have an 8851 configured in SIP mode with Asterisk, tftp server has a directory Desktops/800x480x24 with List.xml, and the image + thumbnail inside. Image is 800x480x24 as a bmpthumbnail is 139x109x24 as bmp thumbnail renders on the wallpaper select...
Hello, quick question . what is the difference b/w these two destination-patterns? I have a dial peer configured and I was told to change it from #1 to #2  destination-pattern ^310928230[4-5].destination-pattern ^31028230..Thanks!
BigK by Level 1
  • 529 Views
  • 1 replies
Hi, We have deployed CUCM 12.5 for a large enterprise, now they would like to share the same infrastructure for one of their sister organizations. The parent organization has the complete admin control for the collaboration infrastructure; however th...
If an old CUBE data sheet says what is shown in the attached image, does this mean the 2911 will support 200 SIP trunk sessions with the DRAM specified? Not that 512MB is the minimum DRAM, and 200 is the max SIP trunk sessions possible with whatever ...
dbooth by Level 1
  • 781 Views
  • 1 replies
Hello everyone, As we know "Route next hop by calling party" feature in Translation pattern is wildly used to block/allow calls based on calling number. There are tons of doc in web on how to implement the same. I am trying to use this feature to imp...
Shri2 by Level 1
  • 1140 Views
  • 5 replies
